PASM SubRoutines
I am trying to create a PASM subroutine for the following block of code:
When the code is implemented like below, when using pPropllerSim the value of "data_byte" changes to 3 (0b0010):
However, when the below code is ran, "data_byte" does not change
Any help would be appreciated.
IF_NZ AND input, #10 IF_NZ SHR input, #1 IF_NZ ADD data_byte, input IF_NZ SHL data_byte, #1
SPI_READ MOV input, #11 'MOV input, ina TEST input, #01, wz 'Sets wz to 1 if clock is 0 IF_NZ AND input, #10 IF_NZ SHR input, #1 IF_NZ ADD data_byte, input IF_NZ SHL data_byte, #1
SPI_READ
MOV input, #11
'MOV input, ina
IF_NZ call #READ_MOSI
jmp #FINISH
READ_MOSI
AND input, #10
SHR input, #1
SHL data_byte, #1
READ_MOSI_ret ret
FINISH
jmp #FINISH
input long 0
data_byte long 0
DAT org 0 SPI_READ MOV input, #%11 ' [COLOR="#D3D3D3"]MOV input, ina[/COLOR] TEST input, #%01 wz 'Sets wz to 1 if clock is 0 IF_NZ call #READ_MOSI jmp #FINISH READ_MOSI AND input, #%10 SHR input, #1 ADD data_byte, input SHL data_byte, #1 READ_MOSI_ret ret FINISH mov dira, mask mov outa, data_byte rev outa, #{32-}8 waitpeq $, #0 input long 0 data_byte long 0 mask long $00FF0000I suppose I should test on real hardware :P
Thanks kuroneko & Mike.
