Unsoldering — Parallax Forums
Unsoldering
FredBlaisFredBlais Posts: 379
edited 2012-11-20 08:14 in General Discussion
I need to switch a propeller from a board to another (because I don't have qfp prop anymore). I just unsoldered it on one board. A lot of heat has been needed to remove it. Do you think it will still work fine, or I'm wasting my time trying to solder it on the other board, realizing it's grilled?
Fred
    edited 2012-11-20 06:55
    No way to know for sure. You don't need to solder all the pins (P0 to P29 are nor required) on the new board to have it working. Solder the ones you need and see if it can be programmed. If that works you can do some more testing.
  • FredBlaisFredBlais Posts: 379
    No propeller chip found on any serial port :(
