help understanding code
I am working on a project at kansas state university that uses stepper motors. I have acquired many stepper motor drivers and have the code that works with those drivers but I am having trouble understanding it so I can adapt it. The drivers are very simple: wake the board by sending a high to SleepPin, choose direction by sending high or low to DirPin, and send PWM to StepPin to set speed. The following is the code that works but I am having trouble adapting. it uses a limit switch, a direction switch and a 10K pot to determine speed. What specifically is this segment I've put in BLUE doing?
Many thanks,
-Isaac
VAR
long time
long temp
long Stack[20]
long CurrentDir
CON
_xinfreq = 5_000_000
_clkmode = xtal1 + pll16x
SleepPin = 22
ResetPin = 23
PFD = 22
EnablePin = 24
DirSwitch = 7
LimitSwitch = 6
DirPin = 17
StepPin = 18
MS1Pin = 21
MS2Pin = 20
MS3Pin = 19
Forward = 0
Reverse = 1
PUB Main
Cognew(StepMotor,@stack[0])
Cognew(RCMeasure,@stack[10])
PUB StepMotor
dira[StepPin] := 1
dira[DirPin] := 1
dira[MS1Pin] := 1
dira[MS2Pin] := 1
dira[SleepPin] := 1
outa[MS1Pin] := 1
outa[MS2Pin] := 1
outa[MS3Pin] := 1
repeat
if (temp := time) > 350 'If the pot is turned all the way down...
if (ina[LimitSwitch] == 0) 'Make sure the Limit Switch is not triggered...
[COLOR=#020FC0][B]outa[SleepPin] := 1
CurrentDir := outa[DirPin] := ina[DirSwitch]
outa[StepPin] := 1
waitcnt(clkfreq/temp + cnt )
outa[StepPin] := 0
else 'wait for a direction change...
repeat while (ina[DirSwitch] == CurrentDir)
'do nothing...[/B][/COLOR]
else
outa[SleepPin] := 0
PUB RCMeasure
ctra[30..26] := 000 ' Set mode to "POS detector"
ctra[5..0] := 16 ' Set APIN to 16 (P16)
frqa := 1 ' Increment phsa by 1 for each clock tick
repeat
dira[16] := outa[16] := 1 ' Set pin to output-high
waitcnt(clkfreq/100_000 + cnt) ' Wait for circuit to charge
phsa~ ' Clear the phsa register
dira[16]~ ' Pin to input stops charging circuit
repeat 22
waitcnt(clkfreq/60 + cnt)
time := (phsa - 624) #> 0
waitcnt(clkfreq/2 + cnt)
Many thanks,
-Isaac
In the if:
1. set the sleep PIN to 1
2. copy the direction switch to the direction PIN and store it in CurrentDir for later usage (in the else)
3. create a pulse on the step pin
-Isaac
