need help with BS2 functions
quickstart
BS2 functions
Radio Control receiver
trying to read the pulsein:
NEED to know what IO PIN to put it on?
What the word 'STATE' indicates????
ETC.
BS2 functions
ETC.
con ' SHIFTIN Constants MSBPRE = 0 LSBPRE = 1 MSBPOST = 2 LSBPOST = 3 OnClock = 4 ' Used for I2C ' SHIFTOUT Constants LSBFIRST = 0 MSBFIRST = 1 ' SEROUT/SERIN Constants NInv = 1 Inv = 0 cntMin = 400 ' Minimum waitcnt value to prevent lock-up DEBUG_BAUD = 9600 ' DEBUG Serial speed - maximum! DEBUG_MODE = 1 ' Non-Inverted SCL = 28 SDA = 29 #1, HOME, #8, BKSP, TAB, LF, CLREOL, CLRDN, CR, #16, CLS ' PST formmatting control OBJ BS2 : "BS2_Functions" ' Create BS2 Objectterm term : "FullDuplexSerial" VAR long s, ms, us,Last_Freq,Last_FreqB Byte DataIn[50],DEBUG_PIN,DEBUGIN_PIN word RCvar PUB Start 'dira[0] := 0 s := clkfreq ' Clock cycles for 1 s ms := clkfreq / 1_000 ' Clock cycles for 1 ms us := clkfreq / 1_000_000 ' Clock cycles for 1 us Last_Freq := 0 ' Holds last setting for FREQOUT_SET BS2.start (31,30) ' Initialize BS2 Object timing, Rx and Tx pins for DEBUG repeat RCvar := BS2.PULSIN(0,state???) 'MyVariable := BS2.PULSIN(pin,state) term.dec(HOME) term.tx(CLS) term.str(string("RCvar")) term.tx(CR) term.dec(RCvar) WaitCnt(ClkFreq / 2 + Cnt)
Tnx kuroneko, ok understand state better, ill use a one i guess
On where to put pin, i meant where to address it in this bs2 function library, i have it on pin zero.
Hi mike, congrats on 20k responses!
To explain, since i drive you nuts so much lately, im a retired wedding photographer with some programming background in excel application basic. I have almost every parallax sensor running after starting my new hobby 8 months ago
Since im limited in this knowledge, im looking for a semi turn key method for getting the radio control variables to show up using fullduplexserial.
Im struggling with this way, radioloop.spin and pvh_autopilot, which outputs to a tv which doesnt fit in with me monitoring everything with full duplex.
Hope it all makes more sense now.
Tnx, eddie
How many RC channels do you want to monitor?
The pulsein method is pretty slow if you're trying to capture a bunch of channels.
I'm sure I have some code that does what you want with up to six channels. I'll try to find it.
6 channels
I posted my modified (and now tested) object here.
I'm not the author of most of it (and not of the hard parts). I just made the object usable with any of the Prop's I/O pins.
