Sticky Wicket
I'm looking for a eletrically insulating, thermally conductive (somewhat) expoxy adhesive, or at least opinions on which ones have worked best for forum members. My last supply dried up (literally) and before shelling out several hundred dollars for several tubes of the grey, noxious, mix-it-and-pray goop I was wondering if anyone had any brand/model experience (e.g., epo-tek...). Don't care if it's green/environmentally friendly (sorry folks). The intent is to add strength (and some thermal release) to PCB level components. Not so much inerested in potting.
http://www.westsystem.com/ss/
Trying to have electrically insulating and thermally conductive is rather difficult. Most good thermal conductors are also good electrical conductors. You might try mica set on aluminum heat sinks to dump heat to the outside (as the mica insulated the heat sink) and then pot the rest in epoxy of any sort. Of even polyester (used to laminate fiberglass).
