poly/film caps are good for....
rwgast_logicdesign
so i have a massive amount of random metal film, poly sterene, and polyester film caps. i was wondering what these are suitable for besides audio.
im pretty sure the .1ufs arent good for decoupling as they dont filter hi frequency like ceramic right? right now im working on an hbridge circuit based on l293e i was thinking maybe adding some caps as power resivoirs before the ic would be a good idea. also have alot of small caps suitably sized for xtal feedback, but i always see ceramic also used there. od usually just use low esr electros and x7r type ceramic maybe a tant in most designs becuase its what i know.
basically i have tons of film and poly sterene and just looking for a usevothervthan audio which i dont do much of
There is a lot of variation in types of film, too, but there are plenty of articles available to compare the advantages and shortcomings of different types. You are right, they are not a good choice for bypassing. But there you have it, you can add timing and signal processing to your list of potential uses. Oh, surface mount stacked film capacitors are readily available now that get around inductance problems that come from the leads.
