PinOut or documentation for 3 Axis TB6560 stepperdriver
StefanL38
I bought one of this 3-axis-stepper-motordrivers with the TB6560
http://www.ebay.com/itm/TB6560-CNC-3-Axis-Stepper-Motor-Driver-Controller-Board-/271102448568?pt=LH_DefaultDomain_0&hash=item3f1ef713b8
I didn't expected that the package has no documentation. Of course I can test all input pins and all switch-states. But before doing that I want to ask
if somebody has the documentation to this driverboard.
thank you very much for links or tips
best regards
Stefan
best regards
Stefan
http://www.mycncuk.com/forums/attachments/drivers-controllers/1371d1262794611-manual-ebay-tb6560-stepper-motor-driver-boards-tb6560_4axis_driver.pdf
thank you very much for the link. My driverboard is a 3 axis-type and it seems to be from a different manufacturer.
Here's a picture of how the driverboard looks like.
best regards
Stefan
http://www.google.com/url?sa=t&rct=j&q=%223+axis%22+tb6560+stepper+motor+driver+manual&source=web&cd=55&ved=0CIgDEBYwNg&url=http%3A%2F%2Fduxe.ru%2Fload%2F3%2520axis%2520TB6560%2520red.pdf&ei=-SejULWFN-XOigKEzYGIAw&usg=AFQjCNGciLOD7cBg4pp3-sUr3wpA5DrU5A
Also, read every post on this thread before installing the board. The discussion may not apply to your specific board, but it does apply to the tb6560 ic.
http://www.mycncuk.com/forums/drivers-controllers/1532-ebay-tb6560-stepper-motor-driver-boards.html
Rick
wow ! you are fast! Thank you very very much for the links!
This board comes very close to the one I have. though there were still a few differences in the design. How did you find it?
The other board has big diodes at the output-stage. What is the purpose of this diodes? Could I add such diodes to my board?
best regards
Stefan
About a half hour of searching with google. "3 axis" tb6560 stepper motor driver manual
The diodes are probably there to protect the driver modules. Did you read the forum thread I pointed out? If you don't read it and then use more than 24 volts with high inductance motors, you will probably fry the controller like a lot of others have.
