A different approach to 3D printing, A Delta Robot printer — Parallax Forums
    edited 2012-11-12 06:03
    I've seen Rostock and it's impressive, both in speed and build volume. I also saw a homemade CNC machine using a similar design with similar advantages. A delta robot trades off a simpler mechanical design for much more complicate kinematics and path planning. A big advantage is that you don't have the Z axis lifting the Y axis, or vice versa.
    edited 2012-11-12 07:54
    I want that!
    edited 2012-11-12 08:43
    next build will be a delta
    edited 2012-11-12 08:54
    Neat execution. Delta bots are very cool to watch, and they have every advantage in much higher speed and lower moving mass. But considering their high number of high-accuracy, zero-play pivoting joints and (per Martin_H) their infinitely more difficult motion control, and you see pretty quickly how traditional XYZ plotters make better, cheaper, RP machines. :)
    I would bet that those $2.50 Ebay stepper motors could be used just fine to make a homebrew XYZ RP machine. The heater/nozzle/feed remains the most complex and expensive part.
