WizFi Orb Article Code
Hello Parallaxians:
I wrote an article recently about using WizNET WizFi210 Wi-Fi module with Prop BOE...
http://www.digikey.com/us/en/techzone/microcontroller/resources/articles/wi-fi-orb-sees-all.html?WT.z_sm_link=G+_microtzart_1010
...so I thought I'd post the code if anyone wants to play around.
Here's what you'll see on the terminal...
Symbol = .dji
perc = -0.35
trade_date = 20121105
trade_time = 151100
Symbol = .dji
perc = -0.29
trade_time = 151301
As mentioned in the article, this code assumes the WizFi210 has been provisioned with your network parameters (SSID, security, etc.) and also the WizFi210 baud rate should match the setting in the code (WizFi.start), 57.6K in this example. Thanks to the eifficiency of SPIN and high-level functions of the WizFi module (ex: DNS) it only takes about 3KB. I'm using two red and two green leds on the PropBOE to 'ambientize' the DJIA data, would like to do something more creative if I find any spare time. .
-- Tom Cantrell
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
debug : "Parallax Serial Terminal"
WizFi : "FullDuplexSerial"
CON
lenipaddr = 18 'max length ip address string incl. cr/lf
lenxmls = 100 'max length xml field data
DAT
ssid byte "your_ssid",$d,0 'replace with your wlan ssid
website byte "[URL="http://www.google.com",$d,0"]www.google.com",$d,0[/URL] 'using Google
get byte "GET /ig/api?stock=" 'finance data api '
symbol byte ".dji",$d,$a,0 'stock symbol ex:.dji,aapl,ibm
numkeys byte 3
keys byte "perc",0,"trade_date",0,"trade_time",0 'xml keys
VAR
byte i,j,k,rxbyte,ipaddr[lenipaddr],xmls[lenxmls]
PUB WizFiOrb 'gets xml data items from a webpage
Debug.start(115_200) 'start debug terminal
WizFi.start(6,7,0,57600) 'start uart connected to WizFi
dira[12..15]~~ 'use two red and two green leds on BOE
waitcnt((clkfreq*3) + cnt) 'some delay to enable/view PST
Debug.str(string($d,"WizFi Orb",$d))
REPEAT
REPEAT
' Debug.str(string($d,"trying to wakeup..."))
WizFi.str(string("at",$d)) 'dummy command to wakeup WizFi
REPEAT
UNTIL WizFi.rx == $5B
UNTIL WizFi.rx=="O"
' Debug.str(string("awake"))
REPEAT
' Debug.Str(string($d,"trying to associate..."))
WizFi.str(string("at+wa="))
WizFi.str(@ssid) '(re)try to associate
REPEAT
UNTIL WizFi.rx == $5B 'look for "["
UNTIL WizFi.rx == "O" 'retry until WizFi says "[OK]"
' Debug.Str(string("associated",$d))
WizFi.str(string("at+dnslookup=")) 'lookup website ip address
WizFi.str(@website)
' Debug.str(string("looking up IP..."))
REPEAT
UNTIL WizFi.rx == ":" ': marks start of returned ip address
REPEAT i from 0 to lenipaddr-1
ipaddr[i] := WizFi.rx 'save ip address digits
' Debug.char(ipaddr[i])
IF ipaddr[i] == $d 'and terminating carriage return
quit
' Debug.str(string("creating socket..."))
REPEAT
WizFi.str(string("at+nauto=0,1,"))'create tcp client connection
i:=0
REPEAT UNTIL ipaddr[i]==$d
WizFi.tx(ipaddr[i]) 'send IP address digits
i++
WizFi.str(string(",80",$d)) 'port 80
REPEAT
UNTIL WizFi.rx=="O" 'retry until WizFi says "[OK]"
' Debug.str(string("created",$d))
' Debug.str(string("connecting..."))
REPEAT
WizFi.str(string("ata2",$d)) 'connect to website server
REPEAT
UNTIL WizFi.rx=="O"
' Debug.str(string("connected",$d))
WizFi.str(@get) 'send http GET request
REPEAT 'skip HTTP response header
i:=WizFi.rx
UNTIL (i==$0a)AND(WizFi.rx==$0d)
k:=0 'k is offset for each key in keys
j:=0 'j is pointer to build xml string
REPEAT numkeys 'for each key in keys
i:=0 'i counts consecutive key char matches
REPEAT 'search incoming webpage for key
CASE WizFi.rx == keys[k+i] 'count consecutive key char matches
TRUE : i++ 'increment if match
FALSE : i := 0 'clear otherwise
UNTIL keys[k+i+1] == 0 'until key matched
k:=k+i+2 'point to next key
REPEAT 'find opening doublequote
UNTIL WizFi.rx == $22
REPEAT 'gather desired data
xmls[j] := WizFi.rx
j++
UNTIL xmls[j-1] == $22 'until closing doublequote
xmls[j-1] := $d 'put carriage return after data
k:=0 'k steps through keys
j:=0 'j steps through xmls
Debug.str(string($d,"Symbol = "))
Debug.str(@symbol)
Debug.str(string(" "))
REPEAT 'display key
Debug.char(keys[k])
k++
UNTIL keys[k]==0
Debug.str(string(" = "))
REPEAT 'display value
Debug.char(xmls[j])
j++
UNTIL xmls[j-1]==$d
IF xmls[0]=="-" 'show on leds
IF xmls[1]=="0"
OUTA[12..15]:=%0010 '..down < 1% = one red led
ELSE
OUTA[12..15]:=%0011 '..down >= 1% = two red leds
ELSE
IF xmls[0]=="0"
OUTA[12..15]:=%0100 '..up < 1% = one green led
ELSE
OUTA[12..15]:=%1100 '..up >= 1% = two green leds
' Debug.str(string("command mode",$d))
REPEAT
WizFi.str(string("+++")) 'request WizFi to command mode
waitcnt(clkfreq + cnt) 'wait for WizFi to command mode
WizFi.str(string("at",$d)) 'confirm WizFi to command mode
REPEAT
UNTIL WizFi.rx == $5B 'look for [
UNTIL WizFi.rx=="O" 'retry until WizFi says [OK]
' Debug.str(string("hang up",$d))
REPEAT
WizFi.str(string("ath",$d)) 'hang-up i.e. disassociate
REPEAT
' Debug.str(string("sleep",$d))
WizFi.str(string("at+psdpsleep",$d)) 'put WizFi to sleep
waitcnt((clkfreq*45)+cnt) 'put MCU to sleep
Symbol = .dji
perc = -0.35
trade_time = 151100
Symbol = .dji
perc = -0.29
trade_time = 151301
-- Tom Cantrell
We are most honored to have you on the forums. You're proof that there's a bunch of talent out there that doesn't frequent our forums.
The article was very clear and I hope to use the code myself at some point in the future.
I'm realizing it was 20+ years ago that this kid aptly named Chip showed up on my doorstep with his PIC-programmer gadget. And I've been a big fan of Parallax ever since! And how fortunate he had a brother Ken to help run the business with class & passion. I've tried a zillion SBCs over the years, but when I have a brainstorm and want to get something working right now I reach for Parallax. PS: Don't take my non-presence on the forums personally, I'm just kind of anti-social (media :=).
Mike G: The WizNet folks pointed me to the work you're doing with their wired Ethernet chip and it's quite impressive! So impressive I implore you not to look at my toy program or comment thereupon :=) If there's meaningful takeaway from the article it's a) 'Embedded Wi-Fi' taking off, b) 'Big Data' - where is it, who owns/guarantees it, how to use it?, c) idea of 'ambience' vs. staring at a screen.
I'm sure I'll be doing some more projects using Parallax gear Ken, I'll definitely come back and keep you posted.
-- Tom
