Parallax Serial LCD
Hello all,
I am not sure where to post this but being as it is for a final project for school Im putting it here.
I have one of the great parallax lcd's with the serial backpack board on it. I have to interface to an 8051 with the use of Assembly language. I have tried connecting the LCD to the serial output of the 8051 and sending it data but I get nothing from the lcd. P3.0 and p3.1 are transmit and receive lines. I attached two pdfs with the info on the 8051 and the lcd I have (which is the revision e). I have no problem using the lcd with a basic stamp 2 or even the propeller. The project final requires that I use the 8051 and assembly lang.
My project: I am using an adc0809 to look at a white light bouncing off of a colored object through three leds. one red, one green and one blue. They are all matched in intensity so I should get a good value from them for how much of that color is bouncing back. I want to display the three adc values on the lcd and possibly if I can figure out how to do and if then statement tell you what color you are looking at. This all works well on the basic stamp but I cant use it. Any help would greatly be appreciated. Also I was wondering if the values have to be sent out as ASCII characters to the display.
Startup:
Initialize variable and constants
Clear lcd
Main:
Poll ADC and get values
Put values in registers R0, R1, R2
Output values to lcd
Loop
Mat
Startup:
Clear lcd
Main:
Loop
Mat
As for the 8051 - it's your microcontroller, so you'll have to come up with programming an asynchronous serial ("8N1") output routine.
