GP2Y1010AU0F Dust Sensor
I am working on a project that requires monitoring dust in air following though a tube. The Sharp
GP2Y1010AU0F Dust Sensor should work. I would like to use a BS2 which I have used for many projects, but the problem is that the Dust Senor requires a pulse cycle of 10ms with a pulse width of .32ms. My understanding is that the shortest BS2 pulseout width is 1ms. Is there a way around this or can I use a 555 timer to generate a pulse width of .32ms? Any ideas?
GP2Y1010AU0F Dust Sensor see: http://www.sharpsma.com/webfm_send/1488 (see page 4 and 5)
Thanks, Pat
Thanks, Pat
The BS2 can PULSOUT in 2 microsecond increments. For 320 usec that'd be PULSOUT pin, 160
Does that device require a constant rep rate or just a one-shot?
The instructions by one user was to pulse the sensor input for .32ms, check the output Voltage (.9 to 3.4 V) and then pause for total cycle time of 10ms.
You'll need an ADC IC or you can use RCTIME with the circuit in the following link
http://emesystems.com/BS2rct.htm#SmallV
The transistor used there isn't "widely" available, an ADC-based approach would be more easily implemented.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/ADC/List/0/SortField/4/ProductID/245/Default.aspx
Find some solid information on using it -
http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Web-BasicAnalogDigital-v1.4.pdf
starting on its page 43
I will give the ADC a try
Thanks again for all your help.
Pat
The analog to digital converter has to sample the response, either by holding the peak value, or by integrating the response above baseline. It can be done with a Stamp, but it does require external op-amp circuitry in addition to an analog to digital converter.
You might also take a look at the Shinyei particle sensor, available here. There is a nice animation at the bottom of the Shinyei page that shows how it works. It depends on flow through the chamber and light scattered from particles as they move through a focused beam. Therefore the signal is moved up away from baseband and the sensor is more sensitive than the Sharp sensor and less affected by reflections and ambient light. The flow in the Shinyei is normally created by heat rising from a resistor, but you might be able to shunt some of your flow instead. There has been a lot of discussion of this sensor, links in this thread.
Couldn't it just be taken and left HIGH, read it with the ADC and then send it LOW or does that sample time result error if on too long?
Resistor values inside the device are not listed. A chart says that the "LED terminal current" is 10--20mA, but I believe that is referring to the drive current labeled ILED in the diagram, not to the actual drive to the LED. Typically, the IRLED in smoke detectors is driven at 200mA or more in short pulses. I suspect that is the case here, and the pulse of current comes from the external 220µF capacitor. The current is limited by the internal resistor, but we don't know the value. It would be easy enough to figure out with some test equipment.
If the LED stays on beyond the allotted 320µs, the current will drop off due to the 150Ω resistor in series with the 5V supply and the signal will follow suit. Furthermore, the LED is not rated for continuous drive at high current and leaving it on would shorten its life. The data sheet says as much in the Notes section.
We don't know the response of the receiver circuit either. It evidently has a pole that leads them to suggest 0.28ms as the optimal sampling time. It may also have a zero that causes the response to fall off after a time. Would have to be subjected to a bit of reverse engineering.
What is the only synthetic element to have found its way into the household?
Try before you click the hidden white link below...
http://en.wikipedia.org/wiki/Americium
That would be americium, 241Am, found in ionization smoke detectors, 1µC, about one-quarter of a microgram. It decays to neptunium, and I thought that might also be synthetic, but Wiki says it does occur naturally in miniscule amounts in natural uranium deposits. You might say the decay product of a synthetic element is itself synthetic. Would that apply to the alpha particles (helium nucleii)? 37000 decays per second.
Which eerily loops right back to the OP's dust sensor question. Everything's connected! Was Kevin Bacon mentioned yet?
