LCD Display issues
Hello,
I have Rev E 2 x16 non back lit LCD that suddenly quit working. The display shows dark blocks along the top row and nothing across the bottom row.
The test mode only works if I apply power to the center pin and ground the data RX pin, and turn up the display contrast. Is the display dead? Is there some way to reset the display?
Thank You
Steve
Thank You
Steve
Thank you for your reply. This situation is a bit of a paradox since the test mode works, but only if the display is wired incorrectly.
Here is the a description of the setup. Only 2 wires are used, 5V and GND. NO signal is used for the time being. Both DIP switches OFF.
If I apply 5V and GND to the correct pins on the display I get the top row black blocks I described.
If I apply 5V to the correct pin and GND to the RX pin the the Test message is displayed and the little PAC man eats the letters.
Is it possible the firmware is corrupted somehow? I try to be careful, but it is possible I mis connected the display at some point. Is it possible to damage the unit with only 5V applied to the wrong pin?
Steve
With regard to test mode, if I provide 5V
Rev E CAUTION
DO NOT PROVIDE A SIGNAL TO THE 'RX' PIN BEFORE APPLYING 5 VDC TO THE '5V' PIN. PDF (last page)
Could that trash the RX pin but allow the rest to work?
