TCS3200-DB Output Rate
Is the following code the correct set-up to make my TCS3200-DB sensor run at the maximum output rate? I'm using a Mobostamp. Thanks.
- Ben
' {$STAMP BS2pe}
' {$PBASIC 2.5}
[ I/O Definitions ]
S3 PIN 0
S2 PIN 1
LED PIN 5
Owio PIN 6
OUT PIN 7
[ Initialization ]
PAUSE 10
OWOUT Owio, 1, [$05, $15]
- Ben
' {$STAMP BS2pe}
' {$PBASIC 2.5}
[ I/O Definitions ]
S3 PIN 0
S2 PIN 1
LED PIN 5
Owio PIN 6
OUT PIN 7
[ Initialization ]
PAUSE 10
