Using bluetooth in classroom
Greetings,
I have a high school class running about 12 BoE-Bots and I would like to be able to wirelessly program and control them. I looked into the EasyBluetooth module and the XBee modules; they both seem like systems my students can handle, but I'm kinda leaning toward bluetooth. I was wondering if there would be interference problems using more than one bluetooth module in a classroom. Will the computer recognize only one bluetooth module and remain partnered with it? Any info or advice is greatly welcomed.
With xBee, there are two different incompatible systems. You can replace one xBee firmware with the other system using a utility program, so the same hardware can be used with either system. 802.15.4 is used for point-to-point communications like Bluetooth while ZigBee is the system used for mesh networks where any particular message can be sent to any Zigbee device (using it's address).
