Eddie Bot' with Larger Motors
Hi Everyone,
I was wondering if anyone had some good advice for me regarding the 10-20 amp motor limitations of the Eddie control board. I currently have a nice robot using a powered wheelchair/scooter setup and I was wanting to purchase an Eddie control board and turn it into a slightly larger Eddie bot. I am using Roboteq's AX2550 motor controller connected to a homebrew Propeller board as it stands now.
Seeing all the firmware / code and documentation for the Parallax setup makes me not want to reinvent the wheel. I planned on using the same sensor and encoder arrangement as Parallax does... only my motors are significantly larger. Any one have some ideas or have tried using the PWM signal and outputs off the Eddie board and feeding them into another motor controller? -Alex
I'm using 2 wheelchair motors at 12v but my robot doesn't weight that much
I get about 1.5 amps when the motors are not loaded..
I will do a long drive test this weekend to see how much the driver chips heat up.
I use these to keep track of the voltage and Current flow
https://www.sparkfun.com/products/10643
You cant use them on the motor leads cause the are bi- directional when reversing .
But they work quite well on the battery leads.
They have other amp ranges to.
I just kind of bit the bullet and ordered the Eddie board and related materials. I will see how that treats me with the larger motors. Ill put an extra 20amp fuse off my battery just in case I get into trouble. I don't see any harm in giving it a try, Thanks for your help. -Alex
