URGENT!!! XBee And XStick!!!!
Hi, I'm a beginner of this XBee and XStick.
I have some Problems...
I have a project. It is to send data and receive data wireless using #32440 (Wireless Pack) and #28187 (XStick ZB AT). In the XBee Tutorial pdf, it mention that in #32440 (Wireless Pack), one of the module is serve as the base node and the other is serve as the remote node. USB Cable is connect to the module (base node).
1. How do I get it to communicate from my XStick ZB AT #28187 to my XBee 802.15.4 embedded Antenna module #32440 (Wireless pack) ? What is the code to communicate it in VB 2010?
2. How do I get it to communicate from my XStick ZB AT #28187 to my #32407 (XBee PRO) ?
3. If I use XStick ZB AT #28187, then I still need to use a minimum 2 XBee module in order to communicate right?
4. Can communicate from XStick ZB AT #28187 to XBee 802.15.4 embedded Antenna module #32440 (Wireless pack unit) and #32407 (XBee PRO)? If can, how to do it?
5. Whether the XStick ZB AT #28187 is compatible to XStick ZB #28184?
6. Whether the XStick ZB AT #28187 is compatible to XStick 802.15.4 #28186?
2) You can't. The xBee PRO is an 802.15.4 device.
3) You have to use ZigBee devices with the XStick ZB.
4) No
5) Should be. Both are ZigBee devices.
6) No.
You could get an XStick 802.15.4 to communicate with other 802.15.4 devices like the XBee PRO.
