Additional EEPROMs
Being a nosy newbie, I was reading some of the posts and comparing to documentation.The diagram on page 17 of the Propeller Reference Manual v1.2 shows a 24LC256 EEPROM attached to the SCL and SDA--and Propeller. 3.3v in, ground etc. Pretty straight forward stuff for me at this point. The question came to me when reading about the subject of adding additional EEPROMS. the SCL and SDA "busses" terminate in the drawing on pg 17. I have seen other drawings where the SCL and SDA are open ended. In the case of the reference manual, what must be done to "insert" a second (or even 3rd) EEPROM. If the SCL and SDA are open ended, do you just sort of "plug" in each new EEPROM, changing the A0-A2 binaries to designate addresses? What do you do about the 3.3v power that each one needs do they all draw from the 3.3V supplied to the first EEPROM? Probably should be more than one thread I guess.
VR/Sunblock
VR/Sunblock
Sunblock
If you are using a board with the DIP-8 version of the EEPROM then you could use one of my small adapter boards. You can either leave the jumper in place and let it keep each chip at different addresses or use it as a bank switch adapter to install an extra chip so you could have a couple different programs loaded in it and just switch between them
http://forums.parallax.com/showthread.php?126798-NEW-EEPROM-expansion-%28bank-switch-adapter%29
