Parallax service for MVPL
In the firmware dwd_Eddie ignore encoder errors.spin there are several commands that are not supported or I cannot figure out out to use in Parallax2011ReferencePlatformIoController service for MVPL. I would like to use the BLNK or the BLINK command, is there any way to do that?
At least since it is in the brick service some of the work has been done for you.
Todd
EDIT: I might add that since the Parallax2011ReferencePlatformIoController service is not one of the standard RDS services when you modify and re-compile it it does not create a (User) service so you won't need to modify any of your VPL programs.
Forgive me for poking in, but is this not done when the Build All Samples is run? I have made some various mods to MVPL items and have not yet had to reinstall after running this.
Todd
