Servo Type Cables
ajward
Anyone know of a source for a cable/wire similar to a servo wire, but with four or five conductors? Just looking at a project to place a sensor or two a few feet away from the processor. Thinking of the IR thermometer or 3-axis accelerometer.
Many thanks,
Amanda
Many thanks,
Amanda
I normally just use two three conductor cables side-by-side for a six conductor cable. Easy peasy.
or check ebay for 6 conductor ribbon cable.
jim
https://www.sparkfun.com/products/10648
Whenever possible, I try to use IDCs with that type of ribon cable. so much easier than crimping or soldering connectors.
SparkFun also sells ready made cables with four or five conductors.
Agreed. But if I'm connecting two PCBs together, I don't mind using two rows of headers. I usually only use them when I need six of more wires though. They're also not breadboard friendly.
I will, of course, use the Molex crimp tool.
I offer only the best materials and uncompromising workmanship.
A better quality custom assembly you will find available nowhere.
For 4 conductor cables you may be able to use some of the CD/DVD audio cables that are used in many PC's. Some only have 3 wires used but I've found quote a few that have all four wires.
As example is:
http://www.ebay.com/itm/New-4-Pin-Audio-Cable-CD-DVD-ROM-Drive-to-SoundCard-26-/110741271821
Regarding those 'ready made cables with four and five conductors...
I buy the same locally and in 3, 4, 5, 6, 8, 10, and 12 conductors.
They have one big advantage over ribbon cables in that you can change the order of wiring quite easily to adapt to two different boards.
In other words, if I were to use a five conductor with a sequence of 1,2,3,4,5 at one end; the other end could be something esle - say 2,4,3,5,1 as they come apart and can be re-configured. Quite handy. They also have 2 row connectors so one can use then instead of ribbon cables to configure as you like.
Ribbon cables may be easy to build, but they cannot help you adapt existing boards.
