SimpleIDE: Problem running gcc in a Win 7 installation
Ok, jazzed asked me to post my problem (mentioned in a propeller thread) here, so I do without checking whether there is a similar thread!
I installed SimpleIDE 0.8.5 on my Win 7 Home Premium Netbook. If I load a quickstart demo project and try to run it, I get the following messages:
If I open a command-prompt, change to the project directory and run gcc, objdump and load as given in the log everything works fine!
Just let me know when you need some more information.
Project Directory: C:/Users/Benky/Documents/SimpleIDE/QuickStart/BlinkCogs/ propeller-elf-gcc.exe -o a.out -Os -mlmm -I . -fno-exceptions blinkcogs.c propeller-elf-gcc.exe error ... (0) propeller-elf-objdump -h a.out propeller-elf-objdump error ... (0) Done. Build Succeeded! propeller-load.exe -I C:/Programs/propgcc/propeller-load/ -b QUICKSTART -p COM13 a.out -r Propeller Version 1 on COM13 Ignored 5 bytes. error: failed to open 'a.out'
I think the error message means that the program has been deleted somehow.
Can you list the contents of C:\propgcc\bin ?
The most recent distribution version is packaged with SimpleIDE version 0-8-5.
Thanks.
I've choosen a different folder for the gcc installation, but the installer seems to ignore this when setting the path variable. It's still c:\propgcc\bin.
It's still 0-7-2:
https://sites.google.com/site/propellergcc/downloads/windows-download
Where is 0-8-5?
Meanwhile Leon and others can find the latest packages here: https://code.google.com/p/propside/downloads/list
I downloaded SimpleIDE from the link in the first sticky msg on this forum. It gave me the version 7. I installed and set folders to my preferences and then ran the program. I attempted to run the "hello world" program and got the below output. I then came back to this forum to see if anyone else encountered this problem. I found this thread. It caused me to check my version and I found that I did not have the newest. I uninstalled the first one and reinstalled the second version from the link in this thread. Upon attempting the "hello world" again, I got the same output.
I did not go with all the default folders when I ran the installation but I did adhere to the no spaces in the labels request. I put pictures of the BIN files I have.
I am running Windows Vista - Is this the problem?
I would have like to be able to choose my own folders. I work hard at maintaining all my Prop programming info, files, etc... in a non-cluttered manner so that I may find them easily when I need them.
Anyhow, I'm off and running.............
