Master program remake — Parallax Forums
RsadeikaRsadeika Posts: 3,861
edited 2012-10-25 12:33 in Propeller 1
I spent some time with Spin making the slave0 & master programs, I also spent some time with PropBASIC, now it's time to get back to C.
Below I started to do a C remake of my Spin version of master program. First, I tried to implement the XBee driver code, in C, necessary to get the XBee working. My code seemed to get the XBee working, but I could not get a C version of xbee_driver_Rx() to work. In the C code I tried using fgets, and fgetc with no success. The program below uses a spin2cpp conversion of the Spin code.
I would like to have an explanation for the multiple inits that are necessary for using FILE *term ..., it seems that their should be some way to just initialize it once, and be able to use term in not only main(), but in all the functions(), where it would be necessary. I am still having trouble understanding why, when I have a term running in main(), I can not get another FDS running in do_job1. I am running main() out to a terminal program on pins 25, and 24, but when I try do get do_job1 to use stdout, or use pins 31,and 30, everything falls apart.
The other thing I noticed is that when I initialized FILE *term ..., you have to have both the extern ..., lines of code, and you have to have the _Driver code present. It seems that if you have FullDuplexSerial.c in the compile mix, why do you have to have the extern ..., and _Driver lines of code?
Once I add the filetest.c, and RTC code, I will try to make do_job1 cog behave like my logger cog which I have in the Spin version. That should be fun, I hope it works.
Ray
 * @file Master0.c
 * This is the main Master0 program start point.
#include <propeller.h>
#include <stdlib.h>
#include <stdio.h>
#include <driver.h>
#include <unistd.h>
extern _Driver _SimpleSerialDriver;
extern _Driver _FullDuplexSerialDriver;
_Driver *_driverlist[] = {
    &_SimpleSerialDriver,
    &_FullDuplexSerialDriver,
    NULL
FILE *stdinfile;
FILE *stdoutfile;
volatile int input;
void do_job1(void *arg)
    stdinfile = stdin;
    stdoutfile = stdout;
//    FILE *term = fopen("FDS:115200,25,24","r+");
//    FILE *stdT = fopen("FDS:115200,31,30","r+");
    xbee_driver_Start(27,26,0,9600);
    xbee_driver_At_configval("ATMY",0);
//    int input;
    waitcnt(CLKFREQ + CNT);
//    fprintf(stdT,"Slave0 Temp & Humidity\n");
//    fflush(stdT);
    while(1)
//        input = xbee_driver_Rx();
//        if (input == 0x21)      //0x21 '!' char
//            fprintf(term,"%c",0xD);  //0xD 'CR' carriage return
//            fflush(term);
//        else
//            fprintf(term,"%c",input);
//            fflush(term);
//        usleep(50);
//        fflush(term);
void high(int WCpin)
    unsigned int bits = 1 << WCpin;
    DIRA |= bits;
    OUTA |= bits;
void low(int WCpin)
    unsigned int mask = 1 << WCpin;
    DIRA |= mask;
    OUTA &= ~mask;
void getxb(void)
    while(1)
        if (input < 0x21 || input > 0x21)
            continue;
        else if (input == 0x21)
            fflush(term);
            fprintf(term, "%d\n", 10);
            break;
 * Main program function.
int main(void)
    int stacksize = sizeof(_thread_state_t)+sizeof(int)*3;
    int *stack = (int*) malloc(stacksize);
    int cog;
    cog = cogstart(do_job1, NULL, stack, stacksize);
    fprintf(term,"This is Main\n");
    getxb();
    while(1)
            fflush(term);
        else
            fflush(term);
        usleep(50);
        fflush(term);
    return 0;
  • ersmithersmith Posts: 6,197
    edited 2012-10-20 06:53
    Do not confuse the FullDuplexSerial_Driver from the library and the result of doing spin2cpp on FullDuplexSerial.spin. They happen to have (partially) the same name, but they are completely different things. The C library does not know anything about what spin2cpp does (if you think about it this will be obvious -- spin2cpp is a separate program, not distributed with propgcc and not normally involved in pure C development). Conversely, spin2cpp knows very little about the C library: it's job is to blindly convert spin code into C/C++, and it doesn't really care whether the Spin object is called "foo" or "MyReallyCoolSerialDriver" or "FullDuplexSerial"; they're all the same to it.
    As for your other question, about the FILE *term, there is a big difference between local variables (ones declared inside a function) and global variables (ones declared outside a function). Local variables can only be accessed inside the function, but global variables can be accessed anywhere. If you want to share the term variable, you have to make the variable global.
    Eric
  • RsadeikaRsadeika Posts: 3,861
    edited 2012-10-20 08:50
    Just like I thought, hitting a memory available barrier. I added basic_i2c_driver.c & .h, sRTC.c & .h, and sdFile.c which, if I use a fscanf(term,"%s",buffer) in place of a gets(buffer), it runs out of HUB memory. I am working in CMM mode, and if I switch over to XMMC, then the do_job1 cog does not work. And the program, the way I want it to work, is just a the beginning of its coding.
    This looks like a big program redesign problem, need help from the experts. Not sure if this can be done, the way I think it should be done, using C and the Propeller. I am not even sure that if there was code refinement that that would even make it fit in CMM mode. So, the biggest problem that I can see is trying to get a cog to run in XMMC mode, in other words to have it work like the program outline below.
    I already tried using pthreads, that did not work out. I would need a thread that acted like a cog, which does not work that way. The only other thing that is left, is trying to use a cog_c style, which is way to complex for me to even attempt to try. And in my opinion, probably would not do what I want it to do anyway. So, does my master program have to start looking for a new chip to work with?
    Ray
     * @file Master0.c
    #include <stdlib.h>
    #include <stdio.h>
    #include <driver.h>
    #include <unistd.h>
    //_Driver *_driverlist[] = {
    //    &_SimpleSerialDriver,
    //    &_FullDuplexSerialDriver,
    //    NULL
    FILE *stdinfile;
    FILE *stdoutfile;
    volatile int input;
    //    stdinfile = stdin;
    //    stdoutfile = stdout;
    //    SW1 = 0;
    //    int input;
    //    waitcnt(CLKFREQ + CNT);
    //    fflush(stdT);
        while(1)
    //            fflush(term);
    //        else
    //            fflush(term);
    //        usleep(50);
    //        fflush(term);
        DIRA |= bits;
        OUTA |= bits;
    void low(int WCpin)
        DIRA |= mask;
        OUTA &= ~mask;
    void getxb(void)
        while(1)
                continue;
                fflush(term);
                break;
    void continousXB(void)
        while(1)
                fflush(term);
            else
                fflush(term);
            usleep(50);
            fflush(term);
    int main(void)
        int cog;
        int num;
        char *tokens[20];
        uint8_t buffer[80];
    //    getxb();
        while(1)
            fprintf(term,"> ");
            fflush(term);
            fgets(term,40,buffer);
    //        fscanf(term,"%s",buffer);
            num = tokenize(buffer, tokens);
            num = CheckRedirection(tokens, num);
            if (num == 0) continue;
            if (!strcmp(tokens[0], "help"))
                Help();
            else if (!strcmp(tokens[0], "quit"))
                break;
            else if (!strcmp(tokens[0], "getxb"))
                getxb();
            else
                fprintf(term, "Invalid command\n");
            CloseRedirection();
        fprintf(term,"System Stop!\n");
        return 0;
  • jnmljnml Posts: 14
    edited 2012-10-20 12:43
    Rsadeika wrote: »
    Have you tried to check the option to use simple printf or tinylib (in beta only IIRC)? Usually (in the later case) it can shave off easily like 10kb of code.
    Also, in more than one place I noticed that you're fopen-ing 'term' with "r+" but then writing to it by fprintf instead. Either I misuderstood something or this is not supposed to work unless a write mode is used. Same with 'stdT'.
    -j
    edited 2012-10-21 10:35
    I decided to give the pthread(s) another try, and it is sort of working like I expect. Since I am doing my program terminal IO from do_job2, I had to resort to using fscanf(), I am having mixed results with this. It is not displaying the keypress, and I can not figure out how to get around that. Also, in the remote terminal, I sometimes get characters displayed that I am not sure where they are coming from. So, the remote console interaction is not what I expected.
    I implemented the getxb() command for a test run of the XBee, that seems to be working like expect, but the characters that are being output, is sometimes not the full line that I expect. I think there is a timing issue between the pthreads, but I am not sure.
    The other concern that I have is that when one of the pthreads grows in terms of lines of code, will the timing have to be fine tuned to make it work correctly? In do_job1, I have the LED that is flashing at a one second rate, and in do_job2, I have a sleep(1) in the while(1) loop, so they seemed to be balanced, but are not behaving correctly. Any ideas as to how to fix the mentioned problems?
    Ray
     * @file master.c
     * This is the main master program start point.
    #include <stdio.h>
    #include <pthread.h>
    #include <unistd.h>
    //    NULL
    FILE *stdinfile;
    FILE *stdoutfile;
    volatile int input;
    void *do_job1(void *arg)
       // FILE *term2 = fopen("FDS:115200,31,30","r+");
        pthread_set_affinity_thiscog_np();
        pthread_detach(pthread_self());
        printf("do_job1 started\n");
        while(1)
            high(16);
            usleep(500000);
            low(16);
            usleep(500000);
            //usleep(250);
    void *do_job2(void *arg)
        FILE *term2 = fopen("FDS:115200,25,24","r+");
        int num;
        char *tokens[20];
        uint8_t buffer[80];
        fprintf(term2,"do_job2 started\n");
        while(1)
            fprintf(term2,"> ");
            fflush(term2);
            fscanf(term2,"%s", buffer);
                Help();
                getxb();
            else
                fprintf(term2,"Invalid command\n");
            CloseRedirection();
            sleep(1);
    void Help()
        fprintf(term2,"Commands are: help, cat, rm, ls, ll, echo, cd, pwd, mkdir\n");
        fprintf(term2,"              rmdir, time, date, setclock, settime, and quit.\n");
    void getxb(void)
        while(1)
                fprintf(term2,"%c",input);
                fflush(term2);
                continue;
                fprintf(term2, "%d\n", 0x10);
                fflush(term2);
                break;
        DIRA |= bits;
        OUTA |= bits;
    void low(int WCpin)
        DIRA |= mask;
        OUTA &= ~mask;
    pthread_t thr[1];
    pthread_t thr1[1];
    int main(int argc, char* argv[])
        int i;
        printf("This is a threaded session\n");
        pthread_create(&thr[i], NULL, do_job1, NULL);
        pthread_create(&thr1[i], NULL, do_job2, NULL);
        printf("Threads launched\n");
        while(1)
            usleep(5);
        return 0;
  • jazzedjazzed Posts: 11,803
    edited 2012-10-21 14:32
    Rsadeika wrote: »
    I decided to give the pthread(s) another try, and it is sort of working like I expect. ....
    Please don't use waitcnt with pthreads. Use usleep instead.
    edited 2012-10-23 08:07
    What the heck! The program below needs some further explanation. Below I am using pthreads, just to see if I run into any unexpected behavior, which I did. The first thing is in do_job1, I have a high(16), which I put in just for a visual that do_job1 is running. I expected that when the program runs, that the LED on pin 16 would stay lit all the time, but instead it flashes, how come?
    The second thing is, I am using a DNA board, and I have it set with XMMC mode. Now in this program, a FullDuplexSerial.c(spin2cpp) is being implemented via xbee_drive.c(spin2cpp). Since the FullDuplexSerial.c program implements a cog, why is this program still able to run, I thought that cogs did not work in XMMC mode?
    I am going in a different direction with this program, I will be creating a C# program that will actually take the data, that will be coming via pins 31,30, and the C# program will manipulate the data, either for display on the screen, or create a CSV file for further manipulation. Also from the C# program, I will try to control things that are running in the pthreads, for example the slave0 xbee that is sending data.
    Ray
     * @file testLEDs.c
     * This is the main testLEDs program start point.
    #include <stdio.h>
        NULL
        high(16);
        int input;
        while(1)
            xbee_driver_Rxflush();
            while(1)
                    printf("%c",input);
                    fflush(stdout);
                    continue;
                    printf("%d\n", 0x10);
                    fflush(stdout);
                 break;
    //        high(16);
    //        usleep(500000);
    //        low(16);
    //        usleep(500000);
            sleep(2);
        printf("do_job2 started\n");
        while(1)
            high(17);
            usleep(400000);
            low(17);
            usleep(400000);
    //        usleep(250);
    void *do_job3(void *arg)
        printf("do_job3 started\n");
        while(1)
            high(18);
            usleep(600000);
            low(18);
            usleep(600000);
    //        usleep(250);
    void *do_job4(void *arg)
        printf("do_job4 started\n");
        while(1)
            high(19);
            usleep(400000);
            low(19);
            usleep(400000);
    //        usleep(250);
    void *do_job5(void *arg)
        printf("do_job5 started\n");
        while(1)
            high(20);
            usleep(500000);
            low(20);
            usleep(500000);
    //        usleep(250);
    void *do_job6(void *arg)
        printf("do_job6 started\n");
        while(1)
            high(21);
            usleep(300000);
            low(21);
            usleep(300000);
    //        usleep(250);
    void *do_job7(void *arg)
        printf("do_job7 started\n");
        while(1)
            high(22);
            usleep(500000);
            low(22);
            usleep(500000);
    //        usleep(250);
    int high(int WCpin)
        DIRA |= bits;
        OUTA |= bits;
        return 0;
    int low(int WCpin)
        DIRA |= mask;
        OUTA &= ~mask;
        return 0;
    pthread_t thr[1];
    pthread_t thr1[1];
    pthread_t thr2[1];
    pthread_t thr3[1];
    pthread_t thr4[1];
    pthread_t thr5[1];
    pthread_t thr6[1];
    int main(void)
        int i;
        usleep(25);
        pthread_create(&thr2[i], NULL, do_job3, NULL);
        pthread_create(&thr3[i], NULL, do_job4, NULL);
        pthread_create(&thr4[i], NULL, do_job5, NULL);
        pthread_create(&thr5[i], NULL, do_job6, NULL);
        pthread_create(&thr6[i], NULL, do_job7, NULL);
        printf("Main job started\n");
        while(1)
            usleep(500);
        return 0;
    edited 2012-10-23 13:31
    I am having a little trouble understanding why the code below is not working as expected. In the pthread program the threads are starting up, but everything stops when it reaches the getc(stdin). I was thinking that by using 'if (InChar == NULL) continue;' , this checks to see if there is a char, if there is no character then it continues on, which in turn all the pthreads keep working. Any ideas as to how to get this loop to continue until it encounters a character?
    Ray
        FILE *stdinfile;
        FILE *stdoutfile;
        stdinfile = stdin;
        int InChar;
        while(1)
            fflush(stdin);
            InChar = getc(stdin);
            if (InChar == '0x100')
                job2LEDh = 17;
            InChar = 0;
            usleep(500);
    edited 2012-10-23 14:03
    First of all, you need to make the stdin unbuffered if you want to read a character without having to type the CR. Also, the input character will never be NULL or '0x100'. You probably meant 0x100 instead of '0x100', but you will not get either value from the serial port.
    edited 2012-10-24 05:37
    Thanks Dave. I just checked out some information dealing with unbuffered stdin, on the WEB. From the examples that I looked at, for my skill level, I am almost certain that I would not be able to accomplish it in PropGCC. Maybe at a later date I will revisit the pthreads and getc() problem that exits for me.
    Ray
    edited 2012-10-24 06:13
    Doing simple things with stdio can be complicated. :) Here's the code I use to make stdin and stdout unbuffered.
    void makeraw()
        setvbuf(stdin, NULL, _IONBF, 0);
        setvbuf(stdout, NULL, _IONBF, 0);
        stdin->_flag &= ~_IOCOOKED;
    edited 2012-10-25 04:13
    In this program I went back to the cogs model. Since I had the LEDs hooked up I have one LED per cog, 7 cogs 7 LEDs. I also wanted to find out what would happen when I added FDS.c, and the xbee_driver. c to the mix. When all 7 cogs are intialized, and the FDS.c is intialized, the program never makes it to "Start of program". I am not really certain if XBee got initialized or not, so does that mean that FDS.c is running in cog 8? I also went back to a simple IO method, after the program gets expanded I will see if there would be room to use a modified filetest code.
    I now have a simple C# program where I have buttons to control the LED in do_job1, and a button to get a getxb() displayed in the main text window. So far it is all working as expected, but this is the easy stuff.
    Ray
     * @file testCleds.c
     * This is the main testCogsLEDs program start point.
    #include <stdio.h>
        NULL
    FILE *stdinfile;
    FILE *stdoutfile;
    volatile int ledon;
    volatile int ledoff;
        while(1)
            high(ledon);
    //        usleep(500000);
            low(ledoff);
    //        usleep(500000);
            usleep(250);
    void do_job2(void *arg)
    //    while(1)
    //        high(17);
    //        usleep(400000);
    //        low(17);
    //        usleep(400000);
            usleep(250);
    void do_job3(void *arg)
        while(1)
    //        high(18);
    //        usleep(600000);
    //        low(18);
    //        usleep(600000);
            usleep(250);
    void do_job4(void *arg)
        while(1)
    //        high(19);
    //        usleep(300000);
    //        low(19);
    //        usleep(300000);
            usleep(250);
    void do_job5(void *arg)
        while(1)
    //        high(20);
    //        usleep(500000);
    //        low(20);
    //        usleep(500000);
            usleep(250);
    void do_job6(void *arg)
        while(1)
    //        high(21);
    //        usleep(400000);
    //        low(21);
    //        usleep(400000);
            usleep(250);
    void do_job7(void *arg)
        while(1)
    //        high(22);
    //        usleep(600000);
    //        low(22);
    //        usleep(600000);
            usleep(250);
    int high(int WCpin)
        DIRA |= bits;
        OUTA |= bits;
        return 0;
    int low(int WCpin)
        DIRA |= mask;
        OUTA &= ~mask;
        return 0;
    void getxb()
        int input;
    //    while(1)
            while(1)
                    printf("%c",input);
                    fflush(stdout);
                    continue;
                    fflush(stdout);
                 break;
    int main(void)
        stdinfile = stdin;
        int cog;
        int stacksize1 = sizeof(_thread_state_t)+sizeof(int)*3;
        int *stack1 = (int*) malloc(stacksize1);
        int cog1;
        cog1 = cogstart(do_job2, NULL, stack1, stacksize1);
        int stacksize2 = sizeof(_thread_state_t)+sizeof(int)*3;
        int *stack2 = (int*) malloc(stacksize2);
        int cog2;
        cog2 = cogstart(do_job3, NULL, stack2, stacksize2);
        int stacksize3 = sizeof(_thread_state_t)+sizeof(int)*3;
        int *stack3 = (int*) malloc(stacksize3);
        int cog3;
        cog3 = cogstart(do_job4, NULL, stack3, stacksize3);
        int stacksize4 = sizeof(_thread_state_t)+sizeof(int)*3;
        int *stack4 = (int*) malloc(stacksize4);
        int cog4;
        cog4 = cogstart(do_job5, NULL, stack4, stacksize4);
        int stacksize5 = sizeof(_thread_state_t)+sizeof(int)*3;
        int *stack5 = (int*) malloc(stacksize5);
        int cog5;
        cog5 = cogstart(do_job6, NULL, stack5, stacksize5);
    //  When I use XBee, this is no longer available.
    //    int stacksize6 = sizeof(_thread_state_t)+sizeof(int)*3;
    //    int *stack6 = (int*) malloc(stacksize6);
    //    int cog6;
    //    cog6 = cogstart(do_job7, NULL, stack6, stacksize6);
        usleep(25);
        int InChar;
        printf("Start of program\n");
        while(1)
            if (InChar == '0')  //48 - LED on
                ledon = 16;
                ledoff = 35;
            if (InChar == '1')  //49 - LED off
                ledon = 35;
                ledoff = 16;
            if (InChar == '2')  //50
                getxb();       // Get a slice of the streaming data
        return 0;
    Hi Ray,
    I tried your code without xbee since I don't have one of those or your xbee c file.
    Of course it doesn't work because you didn't follow Dave Hein's suggestion above.
    Here is a more flexible version of makeraw() to set echo by the driver.
     * pass non-zero to the function to make the driver echo characters.
    void makeraw(int echo)
        if(echo)
            stdin->_flag |= _IOCOOKED;
        else
    If you want all characters echoed by the driver, call the function as "makeraw(1);".
    If you call it with "makeraw(0);" you would be responsible for echoing the character.
    Hope this helps.
    --Steve
