Water pressure gauge with temperature sensor with BS2
Hello
I am looking for pressure gauge which i can install and can also get the water temperature i need the reading very fast.
Can anyone please send me the link or where i can find the cheap priced. Pressure gauge with temperature sensor in it.
And works with BS2
And works with BS2
How fast is "fast"?
It this for inside or outside use? What kind of water to you want to test?
If you look at the "Similar Threads" section below, you'll see some links to threads that discuss pressure and temperature sensors.
I don't know if you know this or not, but you can search the forum by using Google's "site" feature.
For example to search for "water pressure gauge" in the forum you'd use:
I think it's easier to use Google's site feature than using the forum's search tool.
