Anyone tried using the Weatherproof Trasnducer?
Publison
Have not seen any chatter on this device since it came out.
https://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/502-14000/List/0/SortField/4/ProductID/755/Default.aspx
Has anyone tried it?
Phil must have gotten a sample.
Jim
Jim
'Looked at the datasheet, which includes a sample schematic. The schematic includes a pulse transformer, which might scare a few potential designers -- needlessly, I might add -- but inductive components tend to do that for some reason.
Time for Phil and others to tell me what a bad idea this is. I'm sort of joking, but I am very glad when someone on the forum straightens me out and saves me a lot of time from pursuing hopeless projects (like using different frequencies to drive an ultrasound sensor).
http://forums.parallax.com/showthread.php?113182-Waterproof-ultrasonic-sensor/page2&highlight=waterproof
The transducers have been mentioned a couple of times on the forum but I don't know of anyone who as used one.
The Data Sheet is not too helpful. Maybe they can turn some of these if people knew how to use them.
Maybe an accurate circuit would scare us all off. By not knowing how hard they are to use, us gullible types might buy them thinking it shouldn't be too hard to make a weather proof ultrasound sensor. (BTW this should be seen in the "just joking font".)
traVis
I bet Ken or Jessica will send an email to Phil, "how much will it cost us to get a working circuit? Where still trying to get WiFi going"
Just kiddn'
But, darn it = = = > It says "Do not use it in liquid."
I think it was Phil (or maybe Mike Green) who pointed out the ultrasound wouldn't pass through the water well. You're better off using some sort of water proof speaker (or better yet an underwater fish-finder type transducer).
Maybe a sensor to keep pigeons off your window sill by activating a robotic scarecrow.
Now that I know that ultrasound is too high frequency for sonar, I can get on with something that might work. I suppose I should get an audio sample of the ping from a submarine in a movie and use that as a starting point.
Prowave has a wide and readily available (Element 14, Farnell) line of ultrasonics. Their downloads url has a great catalog with nice data sheets. Also app notes.
Here for example are graphs of the sensitivity and sound pressure level for a 20mm open transceiver vs the same for a 25mm closed transciever.
So it is the impedance, not the frequency that is the problem with generating and monitoring sound underwater. The senors all seem rather expensive to buy separate from the packaged technology.
Of course, a towed array means that one might rent or borrow a boat.
But getting back to these weatherproof transducers....
Does anyone see a good application for them? Maybe a trigger for a pre-recorded audio tape loop on a ice cream truck. When people approach, a message would either change or play.
...and lots and lots and lots of wire!! :0)
