Basic Stamp 1, USB - broblems with terminal
Hi, I have problems with terminal; all the DEBUG information will appear as nonsense text when using Teraterm terminal program or Basic Stamp editor program: Run => Debug => New
When select the right port and with all of variations, still the response is nonsence. But if I take Run => Run (or F9), and upload the new program, all works ok. The response text is as should be.
From that debugger the settings are:
Com port 9, Baud Rate 4800, Parity None, Data Bits 8, Flow control Off, DTR checked, RTS unchecked. All works,
BUT if I open that Debug terminal Run => Debug => New with same settings OR with Teraterm with same settings response is nonsense.
I have also changed From windows XP device manager port settings => Advanced => BM Oprions from 16 => 1.
Also no help.
What could be the broblem?
Also no help.
