HB 25 Mounting — Parallax Forums
HB 25 Mounting
NWCCTVNWCCTV Posts: 3,629
edited 2012-10-19 13:31 in General Discussion
Does anyone know what size the screws for mounting the HB-25 to a bracket are? I thought they were 4/40 but that is the size of the wire mount screw.
  • Ken GraceyKen Gracey Posts: 7,407
    edited 2012-10-17 19:11
    6-32, available from your local hardware store (sorry Eurozoners).
  • NWCCTVNWCCTV Posts: 3,629
    edited 2012-10-17 19:22
    Thanks Ken. Of course, of all the nuts, bolts, screws, etc. I have that is not one of them!!!!!
  • idbruceidbruce Posts: 6,197
    edited 2012-10-18 02:43
    6-32s are the standard size for electrical cover plates, receptacles, and switches. :)
    NWCCTV wrote: »
    When you mount these keep in mind that the mounting holes in are connected to the battery ground. Probably not an issue for most uses but if you aren't careful you can have un-intended ground loops. If bolted directly to a metal chassis/frame you will be making the whole frame ground where it otherwise may be electrically isolated.
    Robert
