Dual thermocouple measurement via Excel in real time
Hello,
I have a project where I need an interface between two thermocouples and a PC's USB port, to allow me to capture their temperature values in Excel (with the appropriate add in) in real time.
Looking for ideas on a low cost interface with cold junction compensation, and a source for a free Excel add in. If Parallax product, must be BASIC STAMP, Not propeller. If no Parallax products available (either as kit, ready to use, or build from scratch), please advise of other low cost solutions.
http://www.parallax.com/tabid/393/Default.aspx
It appears that the DS2760 Thermocouple Kit #28022 is discontinued, so I am not sure if there are other thermocouple kits available through Sparkfun or elsewhere for use with the stamp. You could piece one together as well by using the schematic on the last page of the 28022 PDF which is still available.
What type of thermocouple? You have to know or decide that before you can order the corresponding version of the chip. Also, be careful, because tricky instrumentation issues can arise when deploying thermocouples.
The chip is an soic8. I noticed that Mikroelektronika has it available for type K (Chromel-Alumel) mounted on a PC board with a connector, Thermo click. There may be others, or DIY.
There are more general approaches that use a low level ADC, a separate reference temperature sensor, and firmware to apply the cold junction compensation and gain corrections. For example, the ADS1118 is a 16 bit analog to digital converter, SPI interface, that is meant specifically to read two independent thermocouples, plus on-chip reference sensor. The evaluation module, ADS1118EVM, is a direct to USB interface for a pair of type K couples. It would seem to be ideal, IFFF if it can be adapted for your direct to PC/Excel data capture.
