blue tooth how to handle incomming / outgoing messages
I have an easy blue tooth device installed on my propeller board of education. I have connected via my PC using java, and I am able send commands and receive in both directions using "Parallax Serial Terminal Plus"
I'm not an expert but I wonder if I can send and receive at exact the same time using the blue tooth device without having problems?
I use the code below to start my code
pst.StartRxTx(0, 1, 0,9600) , not sure about the mode selected?
Any help would be appreciated
PUB StartRxTx(rxpin, txpin, mode, baudrate) : okay{{Start serial communication with designated
pins, mode, and baud.
Parameters:
rxpin - input pin; receives signals
from external device's TX pin.
txpin - output pin; sends signals to
external device's RX pin.
mode - signaling mode (4-bit pattern).
bit 0 - inverts rx.
bit 1 - inverts tx.
bit 2 - open drain/source tx.
bit 3 - ignore tx echo on rx.
baudrate - bits per second.
