Basic stamp program.1
Hello my fellows friends,
I am back with another issu. I am working on a small project, a charger using the solar panel and batteries. I bought a BS1 that I am using to control my voltage. So, I tested the the BS 1 IC that is working very well. Now, connected on my board, I wanted to test the charger. But I don't see the microcontroller from the system. Also, I found out that the 9V battery I connected to the BS1 is discharged. My test ran for about 30 second.
I have two questions:
- Is it normal to obtain this discharge or did I connected something wrong. the test was simple and basically straight forward.
- Second, If my discharge is normal what kind of battery could anyone suggested to me because the charger will be in use for a long periode of time per day or weeks or more?
Thank you
Thank you
Photos and schematics of your hookup may help us find errors or suggest improvements.
Sorry didn't see that you did not have solar panel connected at the time.
Can you post drawing of your solar panel setup / hookup to BS?
Does your solar panel connection includes reverse / discharge protection (diode)?
Since you are experimenting with power source, do you own VOM or are you just fying blindfolded?
BS genrally draws max 50 ma and you should be able to measure the current drawn from your BS battery to eliminate any guesswork.
