Capacitors on pin 8 of a 555 timer circuit.
I'm reading a schematic for a 555 based 1 mHz oscillator circuit, and it has two capacitors (10 nF and 10 uF) from pin 8 to ground. I'm guessing that these are decoupling capacitors. But I have a few questions.
Why two capacitors?
How do they pick the values?
Do they protect the rest of the circuit from the oscillator, or the oscillator from the rest of the circuit?
Why two capacitors?
EDIT: The datasheets recommend a minimum 1uF electro and 0.1uF ceramic at low (output?) frequencies.
http://www.youtube.com/watch?v=vi24SpKYYoQ
Indeed - and everytime I see the 555 mentioned I feel compelled to mention there are CMOS variants of the 555 that are much better behaved - the 7555 for instance. The original 555 can pull 0.5A spikes on switching IIRC, hence the need for thorough decoupling to prevent excessive supply noise.
It makes sense that two capacitors in parallel would approximate a better capacitor based upon their different properties. In another thread I asked about the ability to substitute capacitor types of similar capacitance values and a similar set of issue came.
