Sending string to VFD but cannot send $00 — Parallax Forums
chetw77cruiserchetw77cruiser Posts: 12
edited 2012-10-15 17:12 in Propeller 1
Hello, I am working on a trip computer for automotive use and I am using a serial VFD (vacuum florescent display) for the output. So far I have everything working for the most part.
I have run into a problem with sending a string to a serial VFD. I am using the full duplex serial object to send data but I can not send a character that is something other than 1 to 255, i.e., ZERO. Maybe I am missing something but I am stumped.
Here is a string I am trying to send:
 vfd.str(string($1f, $28, $67, $03,$00))
Or this:
vfd.str(string($1f,$24,$01,$00,$06,$00))
Apparently the string function does not like anything less than 1. If I cannot get this to work, I will need to find a new way of transmitting commands to the vfd. Any ideas?
    edited 2012-10-14 17:10
    Or this:
    Strings in most languages are a string of characters terminated by a null. That is, the null or 00 is a terminator and not a character of the string. You must send this character separately as a character using vfd.tx.
  • chetw77cruiserchetw77cruiser Posts: 12
    edited 2012-10-14 17:24
    I was trying to avoid sending each command separately. Oh well, sometimes you have to learn the hard way.
  • Prophead100Prophead100 Posts: 192
    edited 2012-10-14 17:58
    Except for the power, the VFDs are nice for retro projects and dimming displays. You don't mention which VFD you use but I have always used the individual ascii for commands. When I want to simplify the code, I write short methods to avoid cluttering up the main code. You can even drop it into an objects as a library. It also gives you opportunities to modify the functions. For example, to provide a variety of screen clearing options I use this method with a Noritake GU144X16D-7053B :
    Pub Clear_Screen(Style)
    case Style
    3,4:'Quick Clear
    serial.tx($1B)
    serial.tx($40)
    2:'Quick Scroll Clear
    serial.tx($1F)
    serial.tx($28)
    serial.tx($61)
    serial.tx($10)
    serial.tx($08) 'wl width of byte scrolled, odd caused bounce up and down
    serial.tx($00) 'wh
    serial.tx($2F) 'cl number of times a width is moved
    serial.tx($00) 'ch
    serial.tx($02) 's speed at which byte is moved
    1:'Slow Scroll Clear
    serial.tx($1F)
    serial.tx($28)
    serial.tx($61)
    serial.tx($10)
    serial.tx($00) 'wh
    serial.tx($00) 'ch
    serial.tx($04) 's speed at which byte is moved
    0:'Bouncing Clear
    serial.tx($1F)
    serial.tx($28)
    serial.tx($61)
    serial.tx($10)
    serial.tx($00) 'wh
    serial.tx($20) 'cl number of times a width is moved
    serial.tx($00) 'ch
    serial.tx($0A) 's speed at which byte is moved
    waitcnt(cnt+clkfreq)
    waitcnt(cnt+clkfreq*3)
    return
  • ChrisGaddChrisGadd Posts: 311
    edited 2012-10-15 08:25
    Another common workaround is to use some other value, such as $FF, in place of 0 in strings, and have the code recognize the substitution and send 0. This assumes of course that you never want the send the substituted value.
    CON
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
    tx_pin   = 30
    Baud     = 19_200
    PUB Main
      dira[tx_pin]~~
      outa[tx_pin]~~
      repeat
        str(string($FF,"A","B","C"))		' Send 0 (cls), "A", "B", "C" to serial terminal at 19,200bps
        waitcnt (cnt + 8_000_000)
    PUB str(stringptr)				' Replace the str method in full-duplex serial with this one
      repeat strsize(stringptr)
        if byte[stringptr] == $FF		' $FF is the substitute for 0
          tx(0)
          stringptr++
        else
          tx(byte[stringptr++])
    PUB tx(tx_byte) | t
      tx_byte := (tx_byte | $100) << 1
      t := cnt
      repeat 10
        outa[tx_pin] := tx_byte & 1
        waitcnt (t += clkfreq / baud)
        tx_byte := tx_byte >> 1
      outa[tx_pin]~~
    edited 2012-10-15 11:50
    I like Chris's approach. Perhaps, you could place your hex commands in labeled lists in the DAT section where each line is a set of command characters terminated by a $FF (instead of '0') that can be send with the alternative string method. That way you don't have to keep repeating the strings in your main code.
  • JonnyMacJonnyMac Posts: 9,786
    I've done something like this in the past so I don't have to worry about substitutions:
    dat
    Cmd1            byte    $05, $1f, $28, $67, $03, $00
    pub send_cmd(pntr) | len
      len := byte[pntr++]
      repeat len
        tx(byte[pntr++])
    It costs one extra byte per string, but with them being stored in a DAT section (versus inline), this may actually save a bit of space.
