Help with mouse driver problem.
mynet43
I've been using the mouse driver from the OBEX, mouse.spin. It has what looks like a minor bug, that is causing me problems.
Here is the case I'm working with:
x0=y0=3680
xmax=ymax=106320
mouse_x=55707
mouse_y=49898
I initialize it by the following two lines of code:
mouse.bound_limits(x0, y0, 0, xmax, ymax, 0)
mouse.bound_scales(32, 32, 0)
As a test case, I set the mouse position using:
mouse.bound_preset(mouse_x, mouse_y)
with the values above.
I then retrieve the mouse position using:
mx := mouse.bound_x
my := mouse.bound_y
The problem is, that the values I get back do not always match exactly what are put in.
For instance, in this case, for X, I put in 55707. I get back mx = 55706.
For my purposes I need the exact value returned, since I'm using it to drive an XY table on an electron microscope and it makes a big difference. When this happens, I interpret it as a mouse movement, and move the table when I shouldn't
Does someone understand the mouse.spin code well enough to provide me with a correction to make this deterministic? I suspect it's just a rounding problem.
Thank you for your help and support.
Jim
x0=y0=3680
xmax=ymax=106320
mouse_x=55707
mouse_y=49898
mx := mouse.bound_x
my := mouse.bound_y
Jim
