Please check my code — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2012-10-15 22:34 in BASIC Stamp
After designing and building a 2 Pushbutton circuit on a PCB I wrote the attached code to control one or two HB-25 motor controllers/motors. This is a very simple program in that if the first button is pressed motor 1 goes forward and motor 2 goes in reverse. If the second button is pushed motor 1 goes in reverse and motor 2 goes forward. There is no ramping done. The code works fine and everything works as it is suppose to. I was just wondering if someone could take a look at it and let me know if it looks good or needs changing.
'   {$STAMP BS2}
'   {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' This is a simple pushboutton test for one or two HB-25's. There are 2
' Pushbuttons connected to pins 3 and 4. HB-25 is connected to Pin 15. Pin
' 3 controls forward and pin 4 controls reverse. Future updates for various
' speeds planned.
   ' -----[ I/O Definitions ]----------------------------------
HB25            PIN     15              ' I/O Pin For HB-25
' -----[ Initialization ]--------------------------------------------------
DO : LOOP UNTIL HB25 = 1                ' Wait For HB-25 Power Up
LOW HB25                                ' Make I/O Pin Output/Low
PAUSE 5                                 ' Wait For HB-25 To Initialize
PULSOUT HB25, 750                       ' Stop Motor 1
PAUSE 1                                 ' 1 mS Delay
PULSOUT HB25, 750                       ' Stop Motor 2 (If Connected)
                                        ' The Above 2 Lines May Be Removed
                                        ' if using only 1 motor
' -----[ Program Code ]-----------------------------------------
  DO
                          ' Start DO Loop
IF (IN3 = 1)  THEN        ' Checks if Pushbutton on IN3 is pressed,
                          ' If Yes then send pulseout command to Pin
    PULSOUT HB25, 500       ' 15  to rotate motor 1 forward.
    PAUSE 1                 ' 1 mS Delay For Motor 2 Pulse
    PULSOUT HB25, 1000      ' send pulsout command to pin 15
                          ' to rotate motor 2 reverse.
    PAUSE 10                ' wait 10 ms
ELSE
                          ' If no then
    PULSOUT HB25, 750     ' send pulsout stop command equivelent
                          ' to motor 1.
                          ' to motor 2.
IF (IN4 = 1)  THEN        ' Checks if Pushbutton on IN4 is pressed,
    PULSOUT HB25, 1000      ' 15  to rotate motor 1 reverse.
    PULSOUT HB25, 500     ' send pulseout command to Pin 15 to
                          ' rotate motor 2 forward.
ELSE
                          ' If no then
                          ' to motor 1.
                          ' to motor 2.
 ENDIF                    ' Since there are 2 IF statements there
 ENDIF                    ' needs TO be 2 ENNDIF's.
 LOOP                     ' Continuous loop.
    edited 2012-10-14 11:52
    What happens if you push both buttons at the same time? Does it still work as expected?
    I don't program the BS2 much but I'd think you'd want the first "ENDIF" before the second "IF".
    I also think there's probably a better way of doing this (as I think you're suggesting by asking about the program).
    I think you'd want:
    do
      if button A pressed
        forward 1
        backward 2
      elseif button B pressed
        backward 1
        forward 2
      else ' no button is pressed
        stop both
      endif
    loop
    Have the button you want to take precedence be the first condition test (if).
    edited 2012-10-14 17:36
    No complaint, it works! This is a situation though where the SELECT CASE command along with subroutines could tighten up the code.
    [FONT=courier new][SIZE=1]DO
      SELECT INA >> 2    ' looking at the state of p3 and p4 as one unit
       CASE 1
        GOSUB forward
       CASE 2
        GOSUB backward
       CASE 0
        GOSUB stop
      ENDSELECT
      PAUSE 20
    LOOP[/SIZE][/FONT]
  • NWCCTVNWCCTV Posts: 3,629
    edited 2012-10-15 10:42
    [/SIZE][/FONT]
    I actually forgot about SUB!!!! I know what to do for the STOP command but I am a bit lost on the above code.
    edited 2012-10-15 21:32
    The two "ENDIF" statements confused me for a bit. I understood the code better once I intended it (which would be required in Spin and I've programmed in Spin a lot more than PBASIC).
    Here's the same loop section with proper (IMO) indentation (since Spin has made me think all code should be similarly indented).
    DO
                              ' Start DO Loop
       [COLOR=#ff0000]IF [/COLOR](IN3 = 1)  THEN        ' Checks if Pushbutton on IN3 is pressed,
       [COLOR=#ff0000]ELSE
    [/COLOR]             ' If no then
                                ' to motor 1.
                                ' to motor 2.
          [COLOR=#00ff00]IF[/COLOR] (IN4 = 1)  THEN        ' Checks if Pushbutton on IN4 is pressed,
          [COLOR=#00ff00]ELSE
                                    ' to motor 1.
                                    ' to motor 2.
          [COLOR=#00ff00]ENDIF                    ' Closes second IF statement
    [/COLOR][COLOR=#ff0000]ENDIF                   [/COLOR][COLOR=#ff0000]' Closes first IF statement
    [/COLOR]LOOP                     ' Continuous loop.
    (The forum software keeps messing up the indentation. I think the above is pretty close to what I'm after.)
    Seeing the code this way makes it clear that "IN4" is checked only if "IN3" doesn't equal 1. Before "IN4" is checked a stop command is sent to both motors and if "IN4" isn't equal to one a second stop command is issued. Since the first stop command is redundant, I think the code would be more efficient like this.
    DO
                              ' Start DO Loop
        ELSEIF (IN4 = 1)  THEN        ' Checks if Pushbutton on IN4 is pressed,
        ELSE
                                ' If no then
                                ' to motor 1.
                                ' to motor 2.
        PAUSE 17              ' since no matter what you want a pause only list it once
                               ' use pause length to make entire loop take 20ms to complete
    I think this is the way it should be indented, assuming I'm understanding the BS2's if, elseif, else, endif statements. And someone, please correct me if I have the indentation based on the flow of the program incorrect.
    Of course I'm sure Tracy's code would be better but I do not know enough about the BS2's case statement to help.
    edited 2012-10-15 22:24
    NWCCTV wrote: »
    What that statement does is to grab the state of the input pins p0 to p4 all at once as one binary nibble,
    INA -- captures the input binary value, 4 bits, for example % 0100
    and then shifts that nibble two bits right to isolate the state of pins p3 and p4 where your buttons are attached.
    INA >> 2 -- shifts that value 2 right, for example % 0100 becomes % 0001, p3 is pressed
    That becomes the value used by the SELECT CASE command, and there are 4 possible states of those two buttons, 00,01,10 and 11.
      CASE 1    ' 01 button state
        GOSUB forward
      CASE 2    ' 10
        GOSUB backward
      CASE 0    ' 00
        GOSUB stop
    ENDSELECT
    CASE 3, binary 11, is not included. But could be. Do you see what will happen if both are pressed at once?
    The behavior is a bit different from your program, or Duane's modification. There is not precedence of one button over the other, because the state INA is read all at once at one point in time.
    OK. I understand what you are both saying. I think since this is for testing purposes only I will go with the code Duane posted. Thanks for the help guys. I am now on to testing everything with my Remote. I pretty much have it figureds out and will just need to code it to control the HB-25's. Once that is complete and I have a rolling bot I will work on autononomous control.
