Radio Frequency
Here is what I am building,I will have a laser setup and I have built a module and when the beam gets broken it emits a tone,but what I would like to know is,is there any way to send a tone to a two way radio to alert me that something has broken the perimeter? If so,what module do I need and what about programming?...Thank you in advance!
Welcome to the Parallax forum!
Do you already have a pair of two-way radios that you can devote to this project? If so, what kind are they?
IR sensor with wirelless remote indicator.
I belive it is on 43x MHz ISM no license required frequency.
Probably hackable for your aplication.
I have a pair of midland two way radios,34 mile range with many channels,I was thinking about using channel 8 with a frequency of 467.5625
You should also read the regs regarding non-voice transmissions in the FRS band.
That command would check for the laser input on pin 1, and then it would turn on pin 2.
If you would like I can send you the whole code. Just let me know.
That would be great!!! get with me via email and we can talk about this..Thanks Again! hayesauto55@gmail.com
