Quadrature Encoder - Bonding Acetate (?) to Clear Styrene Sheeting? — Parallax Forums
xanatosxanatos Posts: 1,120
edited 2012-10-20 13:58 in General Discussion
I have printed out several quadrature encoder wheels on laser-printer transparencies - came out great. They are a little flimsy, though, so I want to bond them to some clear styrene sheeting I got from the hobby store (Evergreen Scale Models, Item # 9007, 0.015" thick (0.4mm)) - and I want the bond to be clear, and to last/not peel, not yellow, etc.
What's a good glue to use? 5 minute epoxy? Super Glue? Silicone Sealant? ... For some reason I don't feel "intuitively secure" with any of those choices... :-)
Thanks!
Dave
    edited 2012-10-12 16:55
    I'd use either 2" wide thin film double sided tape, or spray-on Scotch 77 glue.
    Transparencies are glossy & reflective. Are you using reflective sensors? If so, did you test them together yet? Many times IR doesn't behave like you expect.
    Edit: you did say clear, so likely you're using a break beam sensor. The Scotch 77 glue and translucent double sided tape won't be perfectly clear, but may work for you.
  • xanatosxanatos Posts: 1,120
    edited 2012-10-12 17:21
    Yes, break-beam sensor (OPTEK OPB826, DigiKey), IR. Hoping the toner isn't transparent to IR... :-)
    Dave
    edited 2012-10-12 19:05
    Dave,
    If you'd like, email me your artwork and a mailing address, and I'll cut one that's truly opaque on my laser cutter. No charge.
    edited 2012-10-12 19:13
    xanatos wrote: »
    You may be surprised. 940 nm IR blasts easily through black opaque-appearing photographic negatives (the exposed end bits after development). That stuff used to be highly sought after to filter out visible light and let IR pass through unfettered.
    PS: This is all true, but I mainly replied just to use the word "unfettered" in a sentence.
    edited 2012-10-13 16:12
    Dave,
    Phil, you are an awesome human being! Thanks so much, I'll email you. Also - just in case anyone else on the forum can benefit from the quadrature encoder patterns I'm using, I'm uploading the file here. One file is the small 1" round, the other are 2" rounds... hopefully someone can benefit. NOTE: Apparently the forum re-res'd the file... the original was 300DPI, with a single small wheel being 1", and the larger wheels being 2". If anyone wants the full res, PM me.
    Dave
    These patterns were generated (singly) by WheelEncoderGenerator.exe and Codewheel.exe, both available as free downloads. I just replicated them in PhotoShop for this project since I thought there was a chance I might mees a few up :-)
    1024 x 1863 - 198K
    edited 2012-10-13 17:28
    For anyone who's interested, I made the quadrature encoder wheel MOUNTS with a fantastic item I found at Ace Hardware! They are little screw anchors used to provide steel threads in wood. 67 cents a piece! That, three 1-72 screws, washers and nuts, and a die to thread the 5/52" brass rod to 6-32 threads, yeilds a perfect wheel holder. Those little metal wood-steel thread anchor things come in a variety of sizes, so bigger wheels can be used (as well as larger shafts).
    Pic attached... I had NO IDEA how I was going to attach these things, and saw some hugely bulky arrangements on a few sites... this is sleek & sexy! :-) OK, I'm a geek, sorry :-)
    Dave
    1000 x 750 - 87K
  • idbruceidbruce Posts: 6,197
    edited 2012-10-13 17:44
    @Phil
    I am just curious, how are you going to do this. Could your method be used to generate PCB positives?
    Bruce
    edited 2012-10-13 17:48
    Yes, I could certainly generate PC Board positives with this - how transparent is fiberglass PC Board to IR? :-) I also make Circular Gallifreyan art on PC stock using this process :-)
    Dave
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2012-10-13 18:15
    I don't know about IR, but GREEN LED should go through OK.
    BTW, unless your IR sensor filters for only IR any visible LED would work.
    Duane J
    edited 2012-10-13 18:23
    xanatos wrote: »
    For anyone who's interested, I made the quadrature encoder wheel MOUNTS with a fantastic item I found at Ace Hardware! They are little screw anchors used to provide steel threads in wood. 67 cents a piece! Dave
    Could you post a photo just the item that you got from Ace Hardware so I know what I am looking for Thanks
    edited 2012-10-14 08:08
    They're called Tee Nuts. The one pictured above in use on my encoder wheel assembly is "1/2" - but it measures about 0.56", and I would guess that measurement may vary by manufacturer and batch - they don't appear to be a work of precision engineering, but they can be used in one! :-)
    Picture attached here is of a single Tee Nut like that I used above. They come in 1/2", 3/4" 1", etc. The 1-72 screws work perfectly in the pre-drilled brad holes on the 1/2" version (and the center shaft hole is pre-tapped to 6-32 threads)... 2-56 fits the 3/4", and I'd guess 4-40 on the 1".
    500 x 500 - 41K
    edited 2012-10-14 08:17
    Duane J
    I had originally bought a dual-position optical interruptor sensor for this project and that housing does indeed filter for only IR, but I have 1000+ green surface-mount LEDs looking for something to do, and I'm thinking that they would work very well in this application... and eliminate the issues around IR transmission through a printer copy. Phil Pilgrim has made me a truly wonderful offer, cutting out a few of these for me out of Delrin on his laser cutter (which will also eliminate any IR transmission issues!) and those will probably be what I use in the actual item I'm trying to complete by 11/1. But after that... I want to get more into robotics, and I see a lot of these types of things in my future, plus visible light streaming out of things like these just plain looks cool... :-)
    Dave
    edited 2012-10-14 11:13
    Here's a photo of what I was able to come up with:
    The disc itself is 1/32" acetal. I've added a hub, made from 1/16" acetal. The disc can be sandwiched between the hub and T-nut. Two hole circles are included in each part: one set for a #1 screw OD and one set for the root diameter of #1 self-threading screws. The T-nut and hub can be installed as I've shown above or the other way with the hub on the outside. The advantage to having the hub on the inside is that the tips of the self-threading screws face the shaft, rather than outwards. In order to provide additional clearance for the T-nut and hub, I've increased the OD of the disc to 1 3/8". That separates the ID of the inside track from the hub enough that the hub doesn't have to squeeze into the sensor frame.
    640 x 480 - 32K
    edited 2012-10-14 12:39
    Phil, I can't even begin to express how impressed I am with that. Absolutely fantastic. Thank you very much!
    Dave
    edited 2012-10-14 12:59
    I'm glad you like it! I've got four sets ready to go out in tomorrow's mail.
    edited 2012-10-14 16:05
    Dang! That was fast and looks great Phil! Lets see some IR get through that!
    And.....I love T-Nuts also. :) ...and peanuts
    edited 2012-10-14 16:21
    That is a work of encoder art.
    edited 2012-10-20 13:49
    They have arrived, and I am thrilled.
    Fantastic quality - and not only that, I discovered that the transparency black-areas weren't a problem - they block IR just fine. The real problem is that SO DO THE CLEAR AREAS! :-)
    Ya saved me, Phil! Thank you so much!
    The pictures show the encoder wheel mounted to a Tee Nut and shaft with a collar that serves as a bearing. You can also see the dual-sensor optical interruptor I'm using. The system is programmed and reports in feet and inches perfectly... now I have to make the PC Boards... :-)
    Nice, nice work, Phil!
    Dave
    1000 x 750 - 140K
    1000 x 750 - 131K
    Thanks for the kind words, Dave. I'm glad you like it!
