differential and trike steering?
rwgast_logicdesign
ok so ive been working with what i have which isnt alot and unfourtantely i cant find any scrap rc cars.
anyways i was trying to do a 4 wheel bot but do to differences in motors being a couple gears short i decided just to throw a caster wheel on for now. im not very happy just driving the two motors forward directly the thing wont go straight for longer than 20 seconds and the caster has problems turning.
so im thinking i have a servo i could use this to rotate a single wheel or maybe two wheels that roll freely in correraltion with the front diferential wheels. this seems like it would provide more accurate turning radiuses and lock the caster straight when its not turning.
i have never seens a bot with trike style and differential steering is there problem with this?
>>>>Check out post #73 of this thread.<<<<
Casters are evil. I like Rudders...
It's not like I haven't tried to use casters...
Of course Rudders and Casters aren't allways needed...
"You will have to think outside of the box, especially if you don't own a box to begin with..."
Just use what you have on hand, and see what you can come up with.
-Tommy
Sometimes outriggers are! http://www.youtube.com/watch?feature=player_detailpage&v=fuogP2h82B4#t=21s
You know how I love this alternate ending, Ttommy Ttailspin!
There is always going to be issues getting robots to go perfectly straight (wheel slipage, etc) no mater what drive method you choose.
The HERO 1 and HERO Jr robots use three wheels. Each one uses a single wheel for both the steering/drive and the other two wheels spin freely. It works but it doesn't seem to make it any easier to go straight than a robot with differential drive. Personally I think programming and navigation are easier on a robot using differential drive so that is what I would lean toward when making a new robot base. If you add encoders to the main drive wheels then the microcontroller can keep track of the speed of each wheel to make sure they are turning at the same speed. This can help keep it going where you want.
If you want to try something instead of castors you can always use a ball transfer instead. I'm using these on the last couple of robots that I built.
http://www.mcmaster.com/#standard-ball-transfers-for-conveyors/=jqfamf
My biggest reason for 4 wheels besides the straightness issue is my cant seem to get over bumps at all when I use a caster and it falls alot more. The set up i have now should allow me o do tight 180s well enough to flip the bots oreintaion during travel. Im sure it will be harder to coordinate the back steering with the differential drive but im sure its also not going to be the hardest thing in the world.
As I've espoused many times, a good robot starts with a mechanically sound chassis and good solid motors & wheels. All the slick software in the can't make up for bad design or poor fabrication.
http://members.shaw.ca/swstuff/mouse.html
http://retrointerfacing.com/?tag=mouse-encoder
There are many different styles of castors, slides, ball transfers, etc. I've have the best luck using a castors (or ball transfers) front/rear and two differential drive motors. Usually balance the robot so it favors one of the castors (rear works well) and make sure there that both castors don't touch the ground at the same time. Otherwise it can get stuck. Robots with their differential drive wheels near the center can easily turn in place.
The thing is Im not really doing a trike design, my design is alot closer to the last picture Tailspin posted, but instead of having two roating platforms im only using one and differential drive in on the other side. If worst comes to worst I gues I could make the bot stop for a split second 180 the wheels on the servo then use the differential drive to turn.. but since the wheels attached to the servo are fee spinning I should be able to do differential turns while angling the servo at its max velocity.
I think this could work well as it will give me the tight handeling of a 3 wheel differential bot, with the stability of a 4 wheeler (most of the time) and the accuracy of a trike like the one tailspin posted in the figure 8 video..
Or this could all be a huge mess
I have found that I don't need to "180" the rudder wheel, and I only need four rudder positions,
Straight, 45(left/right), and 90.
Originally, I thought I needed more positions, but they are not really needed,
As you can see in the Figure-8 video, the Rudder servo is in roughly the 45 degree range.
When Spotbot is free roaming with IR sensors, I have about six positions per side(left/right).
The Parallax standard servo works just fine, It is plenty fast and strong enough to swing that rubber tire around.
I don't pause at all to move the rudder during a turn,
Only the wildest (rapid full right, forward, to full left turn) movements makes the wheel drag for a split second.
I think Rudder, or "Tiller" steering can add a little accuracy to turning a robot.
Oh, and I could mention that it just looks really cool too..
-Tommy
