How to supply 5 VDC to center terminal on Serial In header on Propeller Servo Ctrlr?
Hello,
I read that I have the option to supply 5V to the Propeller Servo Controller instead of powering from USB; the doc reads "supply 5 VDC to the center terminal on the Serial In header" , but I see two sets of 3 posts on serial in header. So, which of these do I feed the 5V wire? (see pic attahed.) Pin B or E, or somethingelse as I have labeled them?
Steve
Steve
Either B or E. There are both connected together on the PC Board.
