Single wheel for front of robot to turn
NWCCTV
So, I have 2 ideas for the front end of my bot. The first is a single wheel that would be about half the size of the rear wheels. My question is, should I put a small motor for steering purposes only at the top of this or just let it roam freely and let the rear wheels control steering? For some reason this just does not sem like it would be the best approach. My second idea is to create a suspension system similar to an RC car but with a wider turning radius which would have a motor to control steering. I would like to keep it simple but it also needs to function correctly. The rear wheels I had intended on using were lawn mower tires. However, after reading ercos comments in a different thread I have since decided to go with either 8 inch or 10 inch pneumatic wheels.
This is why I was wondering if I should use motor control. I was thinking of forks similar to a motorcycle that has a motor attached to it for steering control.
http://www.vexrobotics.com/276-1902.html
Ten inch wheels, sounds like you want to build a somewhat large robot. Have you ever built a smaller version of what you have in mind? It's amazing what you learn from building the little 'bots. You could build a small prototype out of wood and tinker with it to see what to expect from your caster wheel. Another option could be a track system. I've seen people build small model radio-controlled tanks that can turn on a dime.
It depends a lot on how heavy the front caster is. On my bot it is very heavy and it adversely steers the robot often under certain conditions. I don't have encoders on the main wheels. At slow speeds the caster will take time to straighten out from a turn to go straight. I get a little left over turn when going forward but it is easy to compensate for. The other thing I noticed is on certain angles of terrain the tire can swing out and throw the robots direction off by around 30 degrees, which is kind of annoying, but this is only at low low speeds with a big heavy tire. It is so inexpensive and easy to throw a caster on a robot the movement issues make sense and for the most part are easy to overcome.
A free moving caster is kind of smart on its own. There are so many pros and cons but I'm glad I slapped a $50 pneumatic caster on my first scratch built robot. It let me get past build issues and start driving around. Now I have tons of data on the setup and know what to do next. I think the same thing can apply to any build aspect, front tires with power steering can appreciate the experience gained from a caster setup too.
Oh wow I'm getting all caster happy... There should be a rule you must own at least one robot with a front or rear caster.
