SMD Tool Selection Help
I'm looking to do some SMD soldering of complete board systems, and I need some new tools to do so. I'm looking for suggestions on what to buy. At a minimum, I think I need a reflow oven and a hot air rework station. I'll be building all the boards by hand, and probably with stencils for the paste.
Here is what I think I need:
- Reflow oven
- Hot air rework station
I've budgeted $1300 for everything together. Are there any suggestions on what I should get?
- Reflow oven
Is it likely to work well, or will it just break or (even worse) fry the boards?
Some questions for you:
What size boards?
What complexity of part types? (QFPs, QFNs, SOICs, 0603, 0805, ?)
What volume are you planning?
(thanks for that eBay link, reading the language in the specs was a riot!)
Here is a collection of ovens, most of which appear to be variants on the T-962A:
http://www.ownta.com/wholesale-dropship-repairing-tools/soldering-tools-dropshipping-wholesaler/reflow-soldering-machine/
This one looks like it's the model that the Chinese ripped the T-962A off of. Unfortunately, I see it listed as 220v, which might not be impossible to overcome but it is certainly troublesome:
http://www.amazon.com/MD-2012-Automatic-Lead-Free-Reflow-model/dp/B00892W36A
http://www.madelltech.com/MD5001.html
Or maybe they're all ripping off of SMTmax? Here is the look-alike for $465:
http://www.smtmax.com/detail.php?id=42
There is the Aoyue HHL3000 oven, for $985
http://sra-solder.com/product.php/6383/88/aoyue_hhl3000
At a much higher pricepoint, there is the luxereous LPKF ProtoFlow E (and it's larger brother the S):
http://www.lpkf.com/products/rapid-pcb-prototyping/smd-assembly/soldering/protoflow-e.htm
$4000 http://www.lpkfusa.com/store/pages/productdetail.aspx?pid=384
E2275 ($3000) http://www.printtec.nl/contents/nl/d360.html
And finally, can't forget the reflow oven cleaner...
http://www.amazon.com/MicroCare-Reflow-Oven-Cleaner-Spray/dp/B000132X5G/ref=sr_1_16?ie=UTF8&qid=1350008090&sr=8-16&keywords=reflow+oven
