trying to measure both the level and flow of plastic pellets
I was wondering if anyone might have some suggestions on how to measure both the level of plastic pellets being dumped into a container and when they are flowing through a tube??
I'm not at all sure how to measure their level in the container at this moment but I am thinking that using beams of light would be best to measure when they are flowing through tubes. I'm sorry if this sounds very vauge but the project is new. I'm not fully sure of all my available options yet and am still doing research.
The material im trying to measure ranges from very shinny smooth textures to dull and dusty material.
The tubing is about 2" in diameter and the material ranges from little 0.125" balls to .375" chopped up crud..
Any ideas, shared experience or suggestions would be great as I have just been given the OK to go ahead with prototying and i need to get some sensors to experiment with soon
Thanks!
Thanks!
If the container is large enough I think an ultrasonic sensor would work for measuring the level. For the presence of pellets in a tube - an IR sensor seems appropriate.
How big are the pellets, how big is the tube, how big is the reservoir?
I've seen a really cool method where chunks are carried by entrainment in an air stream, moved a lot of material a long way fast!
The TSL1401 might be good for detecting flow, by using a backlight and measuring and summing the overall shadow area over time as the chips fall in front of it. If the flow is high enough, though, that the chips overlap front-to-back, you will get erroneously low readings.
I was thinking more of an optical flow method, with the axis of the sensor parallel to the flow of the particles. It's reminiscent of a plane (with such a camera) tracking the motion of the ground and estimating ground speed.
Jim
