useing a speeed ultrasonic sonar — Parallax Forums
nvale55@gmail.comnvale55@gmail.com Posts: 15
edited 2012-10-09 17:32 in Propeller 1
Hi
Im currently messing around with some Speeed Ultrasonic Sonar sensors, and would like to know if its possible to modify the Ping object so that the trigger pulse increases from 2 us to 10us? if so how?
    nvale55 I do not know the sensor you describe but about the shortest delay you can specify in Spin is ~9.2us "waitcnt(381 + cnt)" with spin overhead. And it takes about 8us to go from one outa to the next in Spin. Here is the scope output of the code I listed. Maybe one of the experts here will pop in and let you know if this can be done in Spin instead of PASM.
    Con
      _CLKMODE = XTAL1 + PLL16X
      _XINFREQ = 5_000_000
    Var
      long a, b
    Obj
    Pub Main
      dira[a]~~
      repeat
        outa[a]~
        outa[a]~~
    800 x 480 - 21K
