Communicate XBee without using USB cable but XStick???
Hi. I have a project. It is to receive data wireless from the BASIC Stamp to the computer. I want to use XBee Wireless Pack to receive data. I do not want to use USB cable, but using XStick. But as i connect it and program it at the PBASIC, it somehow says that no BASIC Stamp is found. It probably can't work because of the XStick because it did not communicate of the XBee. Is there a way to Communicate it without using USB cable but using XStick???
You cannot program a Stamp directly using xBee. Sorry. The programming "protocol" that the Stamp and the PC use for the programming process is too time sensitive to work directly over xBee. There are some adapters available that work by having a separate microcontroller at each end to buffer the whole program at each end and manage the programming process. The Flash Fly Wireless Programming System is one such product.
