Designing a Quickstart Bluetooth experimenter board. Any interest? — Parallax Forums
edited 2012-10-09 15:10 in Propeller 1
I did a design for an Xbee board like this a while back, but I've got to be honest, those little Bluetooth modules tend to be a little more intriguing to me. The ones which are set in a friendly breakout board are set as "Slave", while if you can access the other connections on the unit itself, you can configure them as "Master" as well. So I thought a "Servo & More" board with an lean toward these modules might be an interesting item. I've also snuck in a connection for the SD Adapter and options for tying RX/TX to a couple of unused I/O pins with jumpers.
This isn't a finished product yet, there's some cleanup and double checking to do, but you'll get the idea.
Thoughts?
Jeff
723 x 486 - 133K
  • MicksterMickster Posts: 2,934
    edited 2012-10-08 01:26
    Definitely interested here....I would order at least one right away. I need a BT link to the Prop so I can interface to the Android platform.
    Cheers
    Mickster
    edited 2012-10-08 06:18
    Another good one, Jeff!
    ...and I just happened to have found a couple of those little Bluetooth modules hiding in my parts pile!
    edited 2012-10-08 07:34
    Jeff
    Does this design still exist? I have also just started working with Xbee.
    Cheers!
    Mickster
  • cavelambcavelamb Posts: 724
    edited 2012-10-08 08:53
    Hi Jeff,
    Yes. Absolutely,
    Just (please) don't cover the touchpads and LEDs.
    Those are the defining features of a Quickstart board and they need to be kept available.
    Richard
    edited 2012-10-08 09:37
    cavelamb wrote: »
    Hi Jeff,
    Yes. Absolutely,
    Richard
    Richard, Sacrificing the 3-wire connection is a pretty big change. If there's enough folks who would want a run of the standard "Servo and more" board with this section opened up, I'd be more than happy to do a run of them.
    Jeff
    edited 2012-10-08 09:38
    Mickster wrote: »
    Mickster
    It's a design I've been pondering over the last few months. I'll see if I can dig it up.
    Jeff
    Jeff
    I understand.
    But 18 of them?
    Perhaps the 3-wire stack could be reduced to 8 and located on the left side where
    that cap is?
