Roll Your Own Basic Authentication
Once you get your Spinneret or embedded app up and running the next logic step is to password protect your stuff. I know this because I have helped a few folks with their Spinneret projects and inevitably Im asked, How do I password protect my web site?.
This is about basic authentication. Basic authentication not the best solution but its better than nothin.
More information from wikipedia.org
http://en.wikipedia.org/wiki/Basic_access_authentication
Basic authentication uses the browser and HTTP headers to persist base-64 encoded user credentials. However, you know this because you just read the Wikipedia wiki above - hint hint.
First, the logic flow.
Authorization header
The authorization header line contains the base-64 encode username and password; web:web
If the Authorization header is not part of the request, then send the WWW-Authenticate header.
The WWW-Authenticate: header field cause the browser to popup an Authentication Required alert. Enter a username and password and click Ok. The browser will base-64 encode the credentials and send credential to the server using the Authorization header.
The base-64 credentials are not decoded on the server. When the server starts, the expected username and password are base-64 encoded and placed in a buffer. When the request comes in from the client only the base-64 strings are compared. This is not a standard, its simply the way I wrote the code.
In the attached demo, you will find a Header.Spin object. This object is used to tokenize the requested header and easily extract URL, header, GET, and POST collections. The demo is using a W5200. Sorry Spinneret users
As soon as I get a chance, I plan to update the Spinneret driver so It can use the same socket interface found in the W5200 driver.
Does the current request contain an Authorization header? NO: Respond with the WWW-Authenticate: Basic realm="insert realm" header YES: Are the username and password correct? NO: Respond with the WWW-Authenticate: Basic realm="insert realm" header YES: Send the requested page
Authorization: Basic d2ViOndlYg==
WWW-Authenticate: Basic realm="localhost"
Question, Logged in fine, when I close the brouwser window , and open a new one up , its already authenticated . Anyway to kick you out each time you close the brouwser ?
Verry nice pice , Any Multsocket demos ?:p. the parseresourse is kinda trikky, with the ongoing xml replys
Do you mean the TokenizeHeader method in HttpHeader?
If you are sending XML on a POST to the server then update the TokenizeHeader method to look for the Content-Type: text/xml. If "text/xml" is found then do not decode the body. Or use GET over POST.
