Using Sensirion SHT-11
I am trying to create a program/driver to read and display the data from the SHT-11 chip. I ran into a problem, I am not sure how to do the conversion of the raw data to a readable Celsius value. The program below compiles, and I get some values, but it is not showing the correct Celsius value. Has anybody done this already, and can show me the way?
Ray
Ray
* @file Sensi_sht11.c
* This is the main Sensi_sht11 program start point.
#include <propeller.h>
#define Dpin 0
#define Cpin 1
int Sendcommand(Cmd)
int32_t result = 0;
DIRA &= ~(1<<Dpin);
OUTA &= ~(1<<Cpin);
OUTA = ((OUTA & (~(1 << Cpin))) | (1 << Cpin));
OUTA &= ~(1<<Dpin);
DIRA = ((DIRA & (~(1 << Dpin))) | (1 << Dpin));
OUTA &= ~(1<<Cpin);
DIRA &= ~(1<<Dpin);
OUTA &= ~(1<<Cpin);
return Writebyte(Cmd);
int Writebyte(Value)
int result = 0;
int _idx__0044;
_idx__0044 = 8;
do {
OUTA = ((OUTA & (~(1 << Dpin)) | ((Value >> 7) & 0x1) << Dpin));
Value = (Value << 1);
OUTA ^= (1<<Cpin);
OUTA ^= (1<<Cpin);
_idx__0044 = (_idx__0044 + -1);
} while (_idx__0044 >= 1);
DIRA &= ~(1<<Dpin);
result = ((INA >> Dpin) & 0x1);
OUTA ^= (1<<Cpin);
OUTA ^= (1<<Cpin);
return result;
int Readtemperature(void)
int Ack;
int result = 0;
Ack = Sendcommand(3);
// SensirionSpin_Wait();
return Readword();
int Readword(void)
int result = 0;
return ((Readbyte(0) << 8) + Readbyte(1));
int Readbyte( Ack)
int result = 0;
DIRA &= ~(1<<Dpin);
int _idx__0043;
_idx__0043 = 8;
do {
result = ((result << 1) | ((INA >> Dpin) & 0x1));
OUTA ^= (1<<Cpin);
OUTA ^= (1<<Cpin);
_idx__0043 = (_idx__0043 + -1);
} while (_idx__0043 >= 1);
OUTA = ((OUTA & (~(1 << Dpin))) | ((Ack & 0x1) << Dpin));
OUTA ^= (1<<Cpin);
OUTA ^= (1<<Cpin);
DIRA &= ~(1<<Dpin);
return result;
int celsius(t)
int ctemp = -39.66 + (0.01 * t);
return ctemp;
* Main program function.
int main(void)
float rawTemp;
float tempC;
waitcnt(CLKFREQ + CNT);
rawTemp = Readtemperature();
tempC = celsius(rawTemp);
printf("%f", rawTemp);
printf(" %f", tempC);
return 0;
I made a Spin version using the Sensirion, and XBee modules, which runs as expected. I also did a spin2cpp, of the Spin versions, both C and C++ versions, the C version would not compile, using SimpleIDE, was complaining about "_main". The C++ version compiled, but was producing the wrong values for the readings.
So, I decided to use the individual functions that got produced in the spin2cpp conversion which is what is shown in the OP. At this point I am not sure what the next step should be.
After looking at the Sendcommand() and Writebyte() functions, I do not know how to verify that they are working correctly, I am at a loss on this one. I think some of the C experts might have to come up with a driver for the Sensirion module, but I guess everybody is very busy doing more important things.
Ray
Massimo
