How precise basic stamp 2 timings can be over wide range of temperatures/etc ?
Hello. I'm building a custom studio flashlight, and want to use basic stamp 2 as the source for pulses of specific duration, to control the power going into the flash lamp. Based on architecture, used type of crystal, interpreter slowdown, temperature change, how much change of actual time in time-based commands I should expect over temperature change in range of 5-50 C ? I'm talking about BASIC STAMP 2, the simplest stamp 2 model.
Also, my software should work in loop, timing of which may be critical. How loop execution time can change with temperature change?
Same as the pulse width. All timings are proportional to the same error percentage.
