Ditch Your Keyboard? Not Likely
Different ain't always better... http://www.designnews.com/author.asp?section_id=1362&doc_id=249848
For instance, the basic design of a bicycle diamond frame hasn't changed much in over a hundred years. People have tried, and will continue to try to build a better mousetrap.
All I want is a regular kind of keyboard, the bigger the clunkier the keys the better. BUT can we please chop off that pesky num pad area that I never use and makes the distance from keyboard to mouse unecessarilly long. Also the Windows keys and caps lock should be banned.
Such a simple desire and so hard to find.
"Douglas Engelbart introduced the chorded keyset as a computer interface in 1968"
http://en.wikipedia.org/wiki/Chorded_keyboard
I know why you posted this link. It looks like it is made from wood......
If my memory is correct I seem to recall some old BYTE magazine issues that talked about alternate keyboards (late 70's or early 80's) and I think there was something similar to this.
Can't anybody keep it simple. I am beginning to hate permutations.
Ban permutations!!!!!
The keyboard may be made of wood, he may have a real patent.... but it looks like he carved it out of a bar of soap -- not the way to troll for investors.
My favorite combination: a programmer Dvorak on a Kinesis keyboard. I've been QWERTY free for two years now.
http://www.kinesis-ergo.com/
Programmer Dvorak Stickers
Well, you could get a lefthanded keyboard instead of your normal one. They're exactly like a noral one, except the numeric keypad is on the other side.
In fact, I'm thinking that it's all a coverup; that most keyboards sold today are the lefthanded version because they suit us perfectly...
I also know of some 'beancounters' that insist on using leftie keyboard because they use the left hand to punch numbers, and the right hand for the mouse.
Both the Winblows and the Caps keys can be pulled off. Then it's just a matter of filling in the holes with Plastic Padding or something.
I am almost ready to remove the CTRL and the ALT and that Windows logo keys. I tend to hit them and get bizarre results interrupting my flow of output. We have reached the point of saturation of GUI features. WE WERE suppose to use F1-F12 for all that.
Just pull off all the unnecessary bottom row key caps and fill the space with hot glue.
More is less, and less is more!!!!!! Keep it simple and ergonomic.
Actually removing that whole bottom row except the space bar would provide a nice space for cleaning out all the debris that falls behind the other keys.
What execellent advice. And a hot glue blob for the caps lock key.
Now, I want to hack the num pad keys off but I suspect things stop working if I take saw to it.
Probably need to install a Propeller to scan what is left.
http://www.amazon.com/AGPtek%C2%AE-Celluon-Projection-Bluetooth-Keyboard/dp/B008ZZ67NG
Hey, you made a funny...
Bean
I just bought a mini-keyboard without the 10-key off to the side. In fact, that is what Parallax was shipping for use with the Propeller in the days that it was first released. There are also tiny keyboard that are great for kids with small hands.
If you really do use hot glue, cover it with some plastic or dirt with stick to it. I would just cut a piece of laser transparency to the size of the hole and smooth that over the top. I have done this with other hot glue projects and it works well.
You can drag Metro off with the mouse or finger (from top to bottom of screen).
