PMB648, bs2, and data streaming results
I'm wondering if I'm doing something wrong.
I've been curious what all is being sent from the pmb648 via my bs2. The default code highlights some features, but by no means demonstrates the units complete feature set.
So, I wrote a bs2 program to feed me all the data from the 648, and what I'm seeing doesn't match what I'd expect to see. It's gps data all right, and I can even match it with strings shown on various sites of what the data should look like.
The problem comes when I try to match the demo code with what I'm seeing as a data dump.
In the demo code, the bs2 searches for RMC, as a string locater before it reads the rest of the information out of the data stream and displays it.
And, obviously, it works just fine, because I see the longitude, latitude, and various other pieces of info (I also found the date and time fields which weren't in the demo program), but what I don't see in my data dump is this RMC string anywhere.
The first line of the read code in my bs2 program goes like this:
However, with my dump code, I'm not seeing that RMC, string anywhere.
Here's the code I'm using to dump the gps data stream to the debug window.
I let the dump go on for a couple minutes, and while I see all kinds of interesting things in the output, including some strings not documented in the strings used by gpsd which is where I got the info I do have on what this should look like, I don't see the RMC characters anywhere in my data dump.
It's obviously there, or the demo program wouldn't work, but I'll be darned if I can find the silly thing.
Anyone see a problem with my code? Am I missing characters?
I'm puzzled here.
SERIN 0, n4800, [WAIT("RMC,"), DEC2 thour,DEC2 tmin, DEC2 tsec, SKIP 7,and it goes on from there to read more values for positioning ones self and date and such.
SERIN 0, n4800, [STR1] DEBUG STR1 GOTO rereadstr1 is defined as a byte.
I'm puzzled here.
I've tried reading multiple bytes, (24 is the longest I can get before getting an out of variable space error, but when reading that many bytes printing them out doesn't work so well. Something else I could try to get the entire stream? It's a basic bs2, unfortunately not a bs2p with scratch ram.
Any ideas?
I used it with GSM module (lot of AT interaction) and with the propeller it is very easy.
There are some examples posted here:
http://forums.parallax.com/showthread.php?136417-Interfacing-to-the-tacktick-NMEA-unit
Massimo
