Logic Analyzer Signals testing bs2 are not accurate at all!!!!!!
rwgast_logicdesign
This is driving me nutty as im trying to learn as much as possible and im having a real hard time here, I just want to view the logic signals of the bs2 Im using a propeller based analyzer with 100mhz bandwith called propalyzer, and I have tied a voltage buffer to it to make the prop pins 5 volt tolerant. Now when I analyze a propeller everything looks fine for example if I flash an LED with a 50% duty cycle my waves are cleanly timed.
So let me explain to get this all out of the way and clear up any questions. I have a propeller board I made, which is overclocked and tested. I then have a wing plugged into it I made using a 74lvc244 which allows for 5 volt tolerant input.
Now I have a quick start programed to togle a pin with a 50% duty cycle im not sure what speed since i didnt save the code but here is what my separate propalyzer board shows me is happening when the the quickstart pin is probed through the 5v buffer wing I made
Ok im sorry about the quality of that I truly am!!!
Now here is some bs2 code
I should see a a 50% duty cycle of 2ms but im not... im seeing this
The hi patches are roughly 2ms but not always, and this gets way worse when I use pulsout to drive a servo when I excpect to see 1ms Hi i see half a ms of these rapid hi/lows im just doing a simple PULSOUT 14, 500...
Im hoping some here can PLEASE help me figure this out, maybe someone else here uses a logic analyzer and can either confirm its the bs2 or something to do with my analyzer
DO
LOW 14
PAUSE 2
HIGH 14
PAUSE 2
LOOP
Should generate a 2ms pulse correct?? becuase im only seeing a 1ms pulse
Regarding the timing "errors" you're noting, I would bet that the Propalyzer settings need to be re-examined.
Have you used propalyzer at all? Jazzed told me to set it to 10us, which I have done what other setting could be awry here? I could list them change them if you see an error. Changing the resalution wouldn not cause timing errors would it? I like propalyzer becuase of the bandwith the only other thing I have that can be used as an analyzer uses sump and can only get 1mhz of bandwith, plus its a pita to flash the firmwares back and forth on it all the time as I use propalyzer for signals and the bus pirate for protocol decoding
DOPULSOUT 14, 1000PAUSE 20LOOP
Here is what im seeing I have circled the time stamps at the bottom when I move my cursor
Im really getting frustrated here as I know im doing something wrong but I cant figure it out, I would really like to be able to use propalyzer well I feel it could help me greatly as a learning tool
