Prop to Prop communication — Parallax Forums
PodionPodion Posts: 90
edited 2012-10-03 16:20 in Propeller 1
Hello
I have 2 prop, they work in series using the this http://forums.parallax.com/showthread.php?134641-DEMO-High-Speed-Multi-Prop-to-Prop-Communication
My problem is that i have 4 button to control 1 light. I have 2 ON and 2 OFF. Wen i click ON the light turn on but wen I click OFF on the client prop the light stay ON.
I what to know if it's possible to use 4 button to turn on and off a single light?
Client code
*  HighSpeed Client        DEMO v1.0a *
*  Author: Beau Schwabe               *
*  Copyright (c) 2011 Parallax, Inc.  *
*  See end of file for terms of use.  *
Revision History:
  Version 1.0   - (09/20/2011) initial release
  Version 1.0a  - (09/26/2011) minor change to detect When the USB plug is connected
                               to the PC.  This prevents unwanted resets.
CON
  ' Set up the processor clock in the standard way for 80MHz on DemoBoard
  _CLKMODE      = xtal1 + pll16x
  _XINFREQ      = 5_000_000 + 0000
    RX_Pin       = 26
    TX_Pin       = 27
    Command      = 00  '' Feature not used in this demo
    Offset       = 0      '' Feature not used in this demo
    USB_Rx       = 31
    USB_Tx       = 30
    RANGE        = 23       'Range is 0 to RANGE.
    SAMPLES      = 2        'Number of samples to pick: 1 to RANGE + 1
    temps        = 1
    _irrpin         = 0     'ir receiver module on this pin
        _device         = 0     'accept any device code
        _dlyrpt         = 6     'delay before acception code as repeat
Round Robin configuration using 2 Propellers:
   │ │   Propeller 1   │               │   Propeller 2   │    │
   ┣─┤RX             TX├──┳───//───┳─┤RX             TX├──┫
    │     Client      │             │     Server      │    
  Vss                      Vss      Vss                      Vss
Round Robin configuration using 3 or more Propellers:
   │ │   Propeller 2   │                  │   Propeller N   │                  │   Propeller 1   │    │
   ┣─┤RX             TX├──┳───/.../───┳─┤RX             TX├──┳───/.../───┳─┤RX             TX├──┫
    │     Client      │                │     Client      │                │     Server      │    
  Vss                      Vss         Vss                      Vss         Vss                      Vss
Note: All resistors tied to Vss are 330 Ohm and are there to establish a transmission line
Note: All resistors between TX and RX are 100 Ohm and are there to current limit the I/O's in the chance
      of a collision.
With round robin, the idea is that you have one buffer that propagated around and around inside the
round robin loop.  To avoid any data collisions, all Propellers are capable of reading any location
within the buffer, however each Propeller has a specific (assigned by the programmer) location that
it can write to.
So in the Demo, there is a 1K long buffer (4K bytes).  As an example Propeller 1 may only write to
locations 0 to 255.  While Propeller 2 can write to locations 256 to 511.  Propellers 3 & 4 depicted
as N because of the expandable nature of round robin would write to the remaining 512 to 1023 locations.
VAR
long   Buffer[10]
long   Buffer1[10]
byte   Pin[10]
long Stack[400],Stack1[400]
byte    numbers[RANGE + 1]
long    seed
long    keycode
OBJ
  hsRX   : "HSp2pRX"                       'High Speed Receive driver
  hsTX   : "HSp2pTX"                       'High Speed Transmit driver
  PST    : "Parallax Serial Terminal"      'RS232 Serial Driver
  rcvir : "ir_reader_sony"
   SN   : "Simple_Numbers"
PUB Main
 Start
PUB Main_IR
rcvir.init(_irrpin,_device,_dlyrpt,true)   'startup
Start_IR1
PUB Start|debugLED
     if ina[USB_Rx] == 0        '' Check to see if USB port is powered
        outa[USB_Tx] := 0       '' Force Propeller Tx line LOW if USB not connected
     else
        cognew(SerialDisplay,@Stack)    '' Initialize serial communication to the PC
    dira[16..23]~~                                      '<- I/O direction for debug LEDs
    repeat
      hsRX.RX(RX_Pin,@Buffer)                           '<- Receive Data from External Propeller
      hsTX.TX(TX_Pin,10,@Buffer,Command,Offset)       '<- Transmit Data to External Propeller
      hsTX.TX(TX_Pin,10,@Buffer1,Command,Offset)       '<- Transmit Data to External Propeller
      hsRX.RX(RX_Pin,@Buffer1)
     Menu_Principal
PUB Start_IR1
  repeat
    keycode := rcvir.fifo_get   'try a get from fifo
    if keycode == -1            'empty try again
      keycode := keycode + 1
      next
    else
    Menu_Principal_IR
PUB Menu_Principal_IR
        ' ~~=on ~=off
  dira[16..21]~~
  [COLOR=#ff0000]case keycode
           1  : bytemove(@Buffer1,@IR_ON,strsize(@IR_ON))
               outa[16]~~
          129 : bytemove(@Buffer1,@IR_OFF,strsize(@IR_OFF))
                outa[16]~[/COLOR]
     2  : !outa[17]
     3  : !outa[18]
     4  : !outa[19]
     5  : !outa[20]
     6  : !outa[21]
     7  :  outa[16..21]~~
     8  : LED
     9  : RANDOM
     22 :  outa[16..21]~
PUB SerialDisplay               'DEBUG ONLY
    PST.Start(19200)
    repeat
      PST.HOME
      PST.dec(Buffer1[9] )                                  '<- Display Data
PUB Menu_Principal
  [COLOR=#ff0000]case Buffer[0]
   1: outa[16]~~
   0: outa[16]~ [/COLOR]
  outa[17] := Buffer[1]
  outa[18] := Buffer[2]
  outa[19] := Buffer[3]
  outa[20] := Buffer[4]
  outa[21] := Buffer[5]
PUB RANDOM | i, j, sample1, sample2
repeat 10
  repeat i from 10 to RANGE                              'Fill numbers array in order.
     numbers[i] := i
  repeat i from 10 to (SAMPLES - 1)
    j := ||?seed // (RANGE - i + 1) + i                 'Pick a number at random from the remaining choices.
    sample1 := numbers[j]
    bytemove(@numbers[i + 1], @numbers[i], j - i)       'Shift the values to make room.
    numbers[i] := sample1
     if sample1 < sample2
        sample2 := sample1
        waitcnt( _xinfreq / temps +cnt)
        outa[16..23]~
        !outa[sample2]
        next
     if sample1 > sample2
        sample2 := sample1
        outa[16..23]~
        !outa[sample2]
        next
     if sample1 == sample2
        next
                                    'Put the selected number in the newly vacated spot.
  bytemove(@Buffer1,@NB1,strsize(@NB1))
PUB LED
  dira[16..23]~~
  outa[16..23]~
repeat 10
   outa[16]~
  !outa[23]
  waitcnt ( _xinfreq  + cnt)
  !outa[23]
  !outa[22]
  !outa[22]
  !outa[21]
  !outa[21]
  !outa[20]
  !outa[20]
  !outa[19]
  !outa[19]
  !outa[18]
  !outa[18]
  !outa[17]
  !outa[17]
  !outa[16]
outa[16]~
bytemove(@Buffer1,@NB2,strsize(@NB2))
DAT
NB1  BYTE 1,0
NB2  BYTE 2,0
PIN0 BYTE 0,0
PIN1 BYTE 1,0
IR_ON BYTE 1,0
IR_OFF BYTE 129,0
Server code
&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;
Copyright (c) 2011 AgaveRobotics LLC.
File....... HTTPServer.spin
Author..... Mike Gebhard
Company.... Agave Robotics LLC
Email...... mailto:mike.gebhard@agaverobotics.com
Started.... 11/01/2010
Updated.... 07/16/2011
About:
  HTTPServer is the designed for use with the Spinneret Web server manufactured by Parallax Inc.
Usage:
  HTTPServer is the top level object.
  Required objects:
        • Parallax Serial Terminal.spin
        • W5100_Indirect_Driver.spin
        • S35390A_SD-MMC_FATEngineWrapper.spin
        • Request.spin
        • Response.spin
        • StringMethods.spin
        • S35390A_RTCEngine.spin
Change Log:
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  MAX_PACKET_SIZE = $5C0 '1472   '$800 = 2048
  RxTx_BUFFER     = $800         '$600 = 1536
  TEMP_BUFFER     = $600         '$5B4 = 1460
  TCP_PROTOCOL    = 01        '$300 = 768
  UDP_PROTOCOL    = 10        '$200 = 512
  TCP_CONNECT     = $04          '$100 = 256
  DELAY           = $10
  MAX_TRIES       = $25
  #0, DONE, PUT, CD
  RX_Pin       = 27
  TX_Pin       = 26
  Offsett       = 0      '' Feature not used in this demo
DAT
  mac                   byte    $00, $08, $DC, $16, $F2, $73
  subnet                byte    255, 255 ,255, 0
  gateway               byte    108,171,79,7  'WAN Default Gateway : 24.230.203.1
  ip                    byte    192,168,0,105  'LAN
  port                  word    5555
  remoteIp              byte    24,230,203,105 'http://www.whatismyip.com
  remotePort            word    80
  uport                 word    5050
  emailIp               byte    0, 0, 0, 0
  emailPort             word    25
  status                byte    $00, $00, $00, $00
  rxdata                byte    $0[RxTx_BUFFER]
  txdata                byte    $0[RxTx_BUFFER]
  udpdata               byte    $0[TEMP_BUFFER]
  fileErrorHandle       long    $0
  debug                 byte    $0
  lastFile              byte    $0[12], 0
  closedState           byte    00
  openState             byte    00
  listenState           byte    00
  establishedState      byte    00
  closingState          byte    00
  closeWaitState        byte    00
  lastEstblState        byte    00
  lastEstblStateDebug   byte    00
  udpListen             byte    00
  tcpMask               byte    11
  udpMask               byte    00
  fifoSocketDepth       byte    $0
  fifoSocket            long    $00_00_00_00
  debugSemId            byte    $00
  debugCounter          long    $00
  stringMethods         long    $00
  closingTimeout        long    $00, $00, $00, $00
  udpLen                long    $00
  time                  byte    "00/00/0000 00:00:00", 0
  httpDate              byte    "Wed, 01 Feb 2000 01:00:00 GMT", 0
  globalCache           byte    $1
NB0   BYTE 999,0
NB1   BYTE 1,0
NB2   BYTE 2,0
NB3   BYTE 3,0
NB4   BYTE 4,0
NB5   BYTE 5,0
NB6   BYTE 6,0
NB7   BYTE 7,0
NB8   BYTE 8,0
NB9   BYTE 9,0
NB22    BYTE 22,0
VAR
  long StackSpace[20]
  long stack[50]
  long    Buffer[10]
  long    Buffer1[10]
  byte    Pin[10]
OBJ
  pst           : "Parallax Serial Terminal"
  Socket        : "W5100_Indirect_Driver"
  SDCard        : "S35390A_SD-MMC_FATEngineWrapper"
  Request       : "Request"
  Response      : "Response"
  str           : "StringMethods"
  rtc           : "S35390A_RTCEngine"
PUB Initialize | id, size, st , x
  debug := 1
  SDCard.Start
  stringMethods := str.Start
  Request.Constructor(stringMethods)
  Response.Constructor(stringMethods, @txdata)
  pst.Start(115_200)
  pause(200)
  'Mount the SD card
  pst.str(string("Mount SD Card - "))
  SDCard.mount(fileErrorHandle)
  pst.str(string("OK",13))
  pst.str(string("Start RTC: "))
  rtc.RTCEngineStart(29, 28, -1)
  pause(200)
  pst.str(FillTime)
  'Start the W5100 driver
  if(Socket.Start)
    pst.str(string(13, "W5100 Driver Started", 13))
    pst.str(string(13, "Status Memory Lock ID    : "))
    pst.dec(Socket.GetLockId)
    pst.char(13)
  if(debugSemId := locknew) == -1
    pst.str(string("Error, no HTTP server locks available", 13))
  else
    pst.str(string("HTTP Server Lock ID      : "))
    pst.dec(debugSemId)
    pst.char(13)
  'Set the Socket addresses
  SetMac(@mac)
  SetGateway(@gateway)
  SetSubnet(@subnet)
  SetIP(@ip)
  ' Initailize TCP sockets (defalut setting; TCP, Port, remote ip and remote port)
  repeat id from 0 to 3
    InitializeSocket(id)
    Request.Release(id)
    pause(50)
  ' Set all TCP sockets to listen
  pst.char(13)
    Socket.Listen(id)
    pst.str(string("TCP Socket Listener ID   : "))
    pst.dec(id)
    pst.char(13)
    pause(50)
  pst.Str(string(13,"Started Socket Monitoring Service", 13))
   x := 6
  cognew(StatusMonitor, @StackSpace)
  pause(250)
  pst.Str(string(13, "Initial Socket States",13))
  StackDump
  pst.Str(string(13, "Initial Socket Queue",13))
  QueueDump
  pst.str(string(13,"//////////////////////////////////////////////////////////////",13))
  Main
PUB Main | packetSize, id, i, reset, j, temp
  ''HTTP Service
  repeat
    comm
    repeat until fifoSocket == 0
      bytefill(@rxdata, 0, RxTx_BUFFER)
      if(debug)
        pst.str(string(13, "----- Start of Request----------------------------",13))
        pause(DELAY)
      else
        pause(DELAY)
      ' Pop the next socket handle
      id := DequeueSocket
      if(id < 0)
        next
      if(debug)
        pst.str(string(13,"ID: "))
        pst.dec(id)
        pst.str(string(13, "Request Count     : "))
        pst.dec(debugCounter)
        pst.char(13)
      packetSize := Socket.rxTCP(id, @rxdata)
      reset := false
      if ((packetSize < 12) AND (strsize(@rxdata) < 12))
        repeat i from 0 to MAX_TRIES
           pst.str(string(13,"* Retry *"))
          'Wait for a few moments and try again
          waitcnt((clkfreq/300 ) + cnt)
          if(packetSize > 12)
            quit
          if(i == MAX_TRIES)
            'Clean up resource request
            Request.Release(id)
            Socket.Disconnect(id)
            reset := true
            if(debug)
              StackDump
              pst.char(13)
              QueueDump
              pst.str(string(13,"* Timeout *",13))
      if(reset)
        next
      Request.InitializeRequest(id, @rxdata)
      if(debug)
        pst.char(13)
        HeaderLine1(id)
      else
        pause(DELAY)
      ' Process router
      Dispatcher(id)
      'Clean up request resource
      Request.Release(id)
      ' This starts the close process -> 0x00
      ' use close to force a close
      bytefill(@txdata, 0, RxTx_BUFFER)
      debugCounter++
  GotoMain
PUB comm
     dira[23]~~
  repeat 1
      hsTX.TX(TX_Pin,10,@Buffer,Command,Offsett)       '<- Transmit Data to External Propeller
      hsRX.RX(RX_Pin,@Buffer1)                         '<- Receive Data from External Propeller
      hsTX.TX(TX_Pin,10,@Buffer1,Command,Offsett)      '<- Transmit Data to External Propeller
  case Buffer1[0]
          1: outa[23]~~
          129: outa[23]~
  return
PRI SendLedResposne(id) | headerLen, qstr,qstr1
  '' Get the query string value
    comm
  qstr :=  Request.Get(id, string("led"))
    qstr1 := Buffer1[0]
  '' Exit if there is no querystring
    if(qstr == 0)
      return false
  '' Turn the LED on if the led= value is "on"
  if  (strcomp(string("on"), qstr ))  or qstr1 == 1
    LedStatus(1)
     Buffer[0] := 1
     qstr1 := 1
   comm
  if (strcomp(string("off"), qstr ))  or qstr1 == 129
    LedStatus(0)
     Buffer[0] := 0
     qstr1 := 129
   comm
  if (strcomp(string("what"), qstr ))
    if(pin[0]) == 1 and qstr1 == 1
      qstr := string("on")
      qstr1 := 1
    else
      qstr := string("off")
      qstr1 := 0
   comm
  '' Build and send the header
  '' Send the value of led= on or off
  headerLen := Response.BuildHeader(Request.GetExtension(id), 200, globalCache)
  Socket.txTCP(id, @txdata, headerLen)
  Socket.txTCP(id, qstr, strsize(qstr))
   comm
  return true
PRI SendLedResposneA(id) | headerLen, qstr
  if(qstr == 0)
    return false
    LedStatus1(1)
    Buffer[1] := 1
    LedStatus1(0)
     Buffer[1] := 0
    if(pin[1])== 1
    else
   comm
  return true
PRI SendLedResposneB(id) | headerLen, qstr
  if(qstr == 0)
    return false
    LedStatus2(1)
    Buffer[2] := 1
    LedStatus2(0)
     Buffer[2] := 0
    if(pin[2])==1
    else
   comm
  return true
PRI SendLedResposneC(id) | headerLen, qstr
  if(qstr == 0)
    return false
    LedStatus3(1)
    Buffer[3] := 1
    LedStatus3(0)
     Buffer[3] := 0
    if(pin[3])==1
    else
   comm
  return true
PRI SendLedResposneD(id) | headerLen, qstr
  if(qstr == 0)
    return false
    LedStatus4(1)
    Buffer[4] := 1
    LedStatus4(0)
     Buffer[4] := 0
    if(pin[4])==1
    else
   comm
  return true
PRI SendLedResposneE(id) | headerLen, qstr
  if(qstr == 0)
    return false
    LedStatus5(1)
    Buffer[5] := 1
    LedStatus5(0)
     Buffer[5] := 0
    if(pin[5])==1
    else
   comm
  return true
PRI SendLedResposneF(id) | headerLen, qstr
  if(qstr == 0)
    return false
    LedStatus6(1)
    Buffer[6] := 1
    LedStatus6(0)
     Buffer[6] := 0
    if(pin[6])==1
    else
   comm
  return true
PRI SendLedResposneG(id) | headerLen, qstr
  if(qstr == 0)
    return false
    LedStatus7(1)
    Buffer[7] := 1
    LedStatus7(0)
     Buffer[7] := 0
    if(pin[7])==1
    else
   comm
  return true
PRI SendLedResposneH(id) | headerLen, qstr
  if(qstr == 0)
    return false
    LedStatus8(1)
    Buffer[8] := 1
    LedStatus8(0)
     Buffer[8] := 0
    if(pin[8])==1
    else
   comm
  return true
PRI SendLedResposneI(id) | headerLen, qstr
  if(qstr == 0)
    return false
    LedStatus9(1)
    Buffer[9] := 1
    LedStatus9(0)
     Buffer[9] := 0
    if(pin[9])==1
    else
   comm
  return true
PRI Dispatcher(id)
  ''Do some processing before sending the response
  comm
  comm
  if(strcomp(Request.GetFileName(id), string("aled.htm"))  AND Request.GetDepth(id) == 1)
    if(SendLedResposne(id))
       comm
      return
   comm
  if(strcomp(Request.GetFileName(id), string("aleda.htm")) AND Request.GetDepth(id) == 1)
    if(SendLedResposneA(id))
      return
  if(strcomp(Request.GetFileName(id), string("aledb.htm")) AND Request.GetDepth(id) == 1)
    if(SendLedResposneB(id))
      return
  if(strcomp(Request.GetFileName(id), string("aledc.htm")) AND Request.GetDepth(id) == 1)
    if(SendLedResposneC(id))
      return
  if(strcomp(Request.GetFileName(id), string("aledd.htm")) AND Request.GetDepth(id) == 1)
    if(SendLedResposneD(id))
      return
  if(strcomp(Request.GetFileName(id), string("alede.htm")) AND Request.GetDepth(id) == 1)
    if(SendLedResposneE(id))
      return
  if(strcomp(Request.GetFileName(id), string("aledf.htm")) AND Request.GetDepth(id) == 1)
    if(SendLedResposneF(id))
      return
  if(strcomp(Request.GetFileName(id), string("aledg.htm")) AND Request.GetDepth(id) == 1)
    if(SendLedResposneG(id))
      return
  if(strcomp(Request.GetFileName(id), string("aledh.htm")) AND Request.GetDepth(id) == 1)
    if(SendLedResposneH(id))
      return
  if(strcomp(Request.GetFileName(id), string("aledi.htm")) AND Request.GetDepth(id) == 1)
    if(SendLedResposneI(id))
      return
  StaticFileHandler(id)
  comm
  return
PRI LedStatus(state)
  pin[0] := state
  return
PRI LedStatus1(stateA)
  pin[1] := stateA
  return
PRI LedStatus2(stateB)
  pin[2] := stateB
  return
PRI LedStatus3(stateC)
  pin[3] := stateC
  return
PRI LedStatus4(stateD)
  pin[4] := stateD
  return
PRI LedStatus5(stateE)
  pin[5] := stateE
  return
PRI LedStatus6(stateF)
  pin[6] := stateF
  return
PRI LedStatus7(stateG)
  pin[7] := stateG
  return
PRI LedStatus8(stateH)
  pin[8] := stateH
  return
PRI LedStatus9(stateI)
  pin[9] := stateI
  return
PRI GotoMain
  Main
PRI StaticFileHandler(id) | fileSize, i, headerLen, temp, j
  ''Serve up static files from the SDCard
  'pst.str(string(13,"Static File Handler",13))
  SDCard.changeDirectory(@approot)
  pst.char(13)
  'Make sure the directory exists
  ifnot(ChangeDirectory(id))
    'send 404 error
    WriteError(id)
    return
  ' Make sure the file exists
  ifnot(FileExists(Request.GetFileName(id)))
    'send 404 error
    WriteError(id)
    return
  ' Open the file for reading
  SDCard.openFile(Request.GetFileName(id), "r")
  fileSize := SDCard.getFileSize
  'WriteResponseHeader(id)
  'BuildHeader(extension, statusCode, expirer)
  if fileSize < MAX_PACKET_SIZE
    ' send the file in one packet
    SDCard.readFromFile(@txdata, fileSize)
    Socket.txTCP(id, @txdata, fileSize)
  else
    ' send the file in a bunch of packets
    repeat
      SDCard.readFromFile(@txdata, MAX_PACKET_SIZE)
      Socket.txTCP(id, @txdata, MAX_PACKET_SIZE)
      fileSize -= MAX_PACKET_SIZE
      ' once the remaining fileSize is less then the max packet size, just send that remaining bit and quit the loop
      if fileSize < MAX_PACKET_SIZE and fileSize > 0
        quit
      ' Bailout
      if(i++ > 1_000_000)
        WriteError(id)
        quit
  SDCard.closeFile
  return
PRI WriteError(id) | headerOffset
  '' Simple 404 error
  pst.str(string(13, "Write 404 Error",13 ))
  headerOffset := Response.BuildHeader(Request.GetExtension(id), 404, false)
  Socket.txTCP(id, @txdata, headerOffset)
  return
'' directory and file handlers
PRI ChangeDirectory(id) | i, found
  'Handle directory structure for this Request
  if(Request.GetDepth(id) > 1)
    repeat i from 0 to Request.GetDepth(id)-2
      'Return if the directory is not found
      ifnot(FileExists(Request.GetPathNode(id, i)))
        return false
      found := SDCard.changeDirectory(Request.GetPathNode(id, i))
  return true
PRI FileExists(fileToCompare) | filenamePtr
'Start file find at the top of the list
  SDCard.startFindFile
  'Verify that the file exists
  repeat while filenamePtr <> 0
    filenamePtr := SDCard.nextFile
    if(str.MatchPattern(filenamePtr, fileToCompare, 0, false ) == 0 )
      return true
  return false
'' Time Methods and Formats
PRI GetTime(id) | ptr, headerOffset
  ptr := @udpdata
  FillHttpDate
  bytemove(ptr, string("<p>"),3)
  ptr += 3
  bytemove(ptr, @httpDate, strsize(@httpDate))
  ptr += strsize(@httpDate)
  bytemove(ptr, string("</p>"),4)
  ptr += 3
  headerOffset := Response.BuildHeader(Request.GetExtension(id), 200, false)
  StringSend(id, @udpdata)
  bytefill(@udpdata, 0, TEMP_BUFFER)
  return
PRI FillTime | ptr, num
 'ToString(integerToConvert, destinationPointer)
 '00/00/0000 00:00:00
  ptr := @time
  rtc.readTime
  FillTimeHelper(rtc.clockMonth, ptr)
  ptr += 3
  FillTimeHelper(rtc.clockDate, ptr)
  ptr += 3
  FillTimeHelper(rtc.clockYear, ptr)
  ptr += 5
  FillTimeHelper(rtc.clockHour , ptr)
  ptr += 3
  FillTimeHelper(rtc.clockMinute , ptr)
  ptr += 3
  FillTimeHelper(rtc.clockSecond, ptr)
  return @time
PRI FillHttpDate | ptr, num, temp
 'Wed, 01 Feb 2000 01:00:00 GMT
  ptr := @httpDate
  rtc.readTime
  temp := rtc.getDayString
  bytemove(ptr, temp, strsize(temp))
  ptr += strsize(temp) + 2
  ptr += 3
  temp := rtc.getMonthString
  ptr += strsize(temp) + 1
  ptr += 5
  ptr += 3
  ptr += 3
  return @httpDate
PRI FillTimeHelper(number, ptr) | offset
  offset := 0
  if(number < 10)
    offset := 1
  str.ToString(@number, @tempNum)
  bytemove(ptr+offset, @tempNum, strsize(@tempNum))
'' SDCard Logger
PRI AppendLog(logToAppend)
  '' logToAppend:  Pointer to a string of test we'd like to log
  if(FileExists(@logfile))
    SDCard.openFile(@logfile, "A")
  else
    SDCard.newFile(@logfile)
  SDCard.writeData(string(13,10,"----- Start "),14)
  SDCard.writeData(FillTime, 19)
  SDCard.writeData(string(" -----"),6)
  SDCard.writeData(@crlf_crlf, 2)
  SDCard.writeData(logToAppend, strsize(logToAppend))
  SDCard.writeData(string("----- End "),10)
  SDCard.closeFile
'' Memory Management
PRI Set(DestAddress, SrcAddress, Count)
  bytemove(DestAddress, SrcAddress, Count)
  bytefill(DestAddress+Count, $0, 1)
'' Socekt helpers
PRI GetTcpSocketMask(id)
  return id & tcpMask
PRI DecodeId(value) | tmp
    if(01 & value)
      return 0
    if(10 & value)
      return 1
    if(00 & value)
      return 2
    if(00 & value)
      return 3
  return -1
PRI QueueSocket(id) | tmp
  if(fifoSocketDepth > 4)
    return false
  tmp := |< id
  'Unique check
  ifnot(IsUnique(tmp))
    return false
  tmp <<= (fifoSocketDepth++) * 8
  fifoSocket |= tmp
  return true
PRI IsUnique(encodedId) | tmp
  tmp := encodedId & $0F
  repeat 4
    if(encodedId & fifoSocket)
      return false
    encodedId <<= 8
  return true
PRI DequeueSocket | tmp
  if(fifoSocketDepth == 0)
    return -2
  repeat until not lockset(debugSemId)
  tmp := fifoSocket & $0F
  fifoSocket >>= 8
  fifoSocketDepth--
  lockclr(debugSemId)
  return DecodeId(tmp)
PRI ResetSocket(id)
  Socket.Close(id)
PRI IsolateTcpSocketById(id) | tmp
  tmp := |< id
  tcpMask &= tmp
PRI SetTcpSocketMaskById(id, state) | tmp
'' The tcpMask contains the socket the the StatusMonitor monitors
  tmp := |< id
  if(state == 1)
    tcpMask |= tmp
  else
    tmp := !tmp
    tcpMask &= tmp
'' W5100 Helper methods
PRI GetCommandRegisterAddress(id)
  return Socket#_S0_CR + (id * $0100)
PRI GetStatusRegisterAddress(id)
  return Socket#_S0_SR + (id * $0100)
PRI SetMac(_firstOctet)
  Socket.WriteMACaddress(true, _firstOctet)
  return
PRI SetGateway(_firstOctet)
  Socket.WriteGatewayAddress(true, _firstOctet)
  return
PRI SetSubnet(_firstOctet)
  Socket.WriteSubnetMask(true, _firstOctet)
  return
PRI SetIP(_firstOctet)
  Socket.WriteIPAddress(true, _firstOctet)
  return
PRI StringSend(id, _dataPtr)
  Socket.txTCP(id, _dataPtr, strsize(_dataPtr))
  return
PRI SendChar(id, _dataPtr)
  Socket.txTCP(id, _dataPtr, 1)
  return
PRI SendChars(id, _dataPtr, _length)
  Socket.txTCP(id, _dataPtr, _length)
  return
PRI InitializeSocket(id)
  Socket.Initialize(id, TCP_PROTOCOL, port, remotePort, @remoteIp)
  return
PRI InitializeSocketForEmail(id)
  Socket.Initialize(id, TCP_PROTOCOL, port, emailPort, @emailIp)
  return
PRI InitializeUPDSocket(id)
  Socket.Initialize(id, UDP_PROTOCOL, uport, remotePort, @remoteIp)
  return
'' Debug/Display Methods
PRI QueueDump
  '' Display socket IDs in the queue
  '' ie 00000401 -> socket Zero is next to pop off
  pst.str(string("FIFO["))
  pst.dec(fifoSocketDepth)
  pst.str(string("] "))
  pst.hex(fifoSocket, 8)
PRI StackDump | clsd, open, lstn, estb, clwt, clng, id, ulst
  '' This method is purely for debugging
  '' It displays the status of all socket registers
  clsd := closedState
  open := openState
  lstn := listenState
  estb := establishedState
  clwt := closeWaitState
  clng := closingState
  ulst := udpListen
  lockclr(debugSemId)
  pst.char(13)
  repeat id from 3 to 0
    pst.dec(id)
    pst.str(string("-"))
    pst.hex(status[id], 2)
    pst.str(string(" "))
    pause(1)
  pst.str(string(13,"clsd open lstn estb clwt clng udps", 13))
  pst.bin(clsd, 4)
  pst.bin(open, 4)
  pst.bin(lstn, 4)
  pst.bin(estb, 4)
  pst.bin(clwt, 4)
  pst.bin(clng, 4)
  pst.bin(ulst, 4)
  pst.char(13)
PRI HeaderLine1(id) | i
  pst.str(Request.GetMethod(id))
  pst.char($20)
  i := 0
  repeat Request.GetDepth(id)
    pst.char($2F)
    pst.str(Request.GetPathNode(id, i++))
PRI Pause(Duration)
  waitcnt(((clkfreq / 1_000 * Duration - 3932) #> 381) + cnt)
  return
PRI StatusMonitor | id, tmp, value
'' StatusMonitor is the heartbeat of the project
'' Here we monitor the state of the Wiznet 5100's 4 sockets
  repeat
    Socket.GetStatus32(@status[0])
    ' Encode status register states
    closedState := openState := listenState := establishedState := {
     } closeWaitState := closingState := 0
      case(status[id])
        $00: closedState               |= |< id
             closedState               &= tcpMask
        $13: openState                 |= |< id
             openState                 &= tcpMask
        $14: listenState               |= |< id
             listenState               &= tcpMask
        $17: establishedState          |= |< id
             establishedState          &= tcpMask
        $18,$1A,$1B: closingState      |= |< id
                     closingState      &= tcpMask
        $1C: closeWaitState            |= |< id
             closeWaitState            &= tcpMask
        $1D: closingState              |= |< id
        $22: udpListen                 |= |< id
             udpListen                 &= udpMask
    if(lastEstblState <> establishedState)
      value := establishedState
      repeat while value > 0
        tmp := DecodeId(value)
        if(tmp > -1)
          QueueSocket(tmp)
          tmp := |< tmp
          tmp := !tmp
          value &= tmp
      lastEstblState := establishedState
    lockclr(debugSemId)
    ' Initialize a closed socket
    if(closedState > 0)
      id := DecodeId(closedState)
      if(id > -1)
        InitializeSocket(id & tcpMask)
    'Start a listener on an initialized/open socket
    if(openState > 0)
      id := DecodeId(openState)
      if(id > -1)
        Socket.Listen(id & tcpMask)
    ' Close the socket if the status is close/wait
    ' response processor should close the socket with disconnect
    ' there could be a timeout so we have a forced close.
    ' TODO: CCheck for a port that gets stuck in a closing state
    'if(closeWaitState > 0)
      'id := DecodeId(closeWaitState)
      'if(id > -1)
        'Socket.Close(id & tcpMask)
    'pause(100)
return
DAT
  approot               byte    "\", 0
  defaultpage           byte    "index.htm", 0
  logfile               byte    "log.txt", 0
  'binFile               byte    "filename.bin", 0
  FS                    byte    "/", 0
  fn                    byte    "filename=", 0
  doublequote           byte    $22, 0
  crlf                  byte    13, 10, 0
  crlf_crlf             byte    13, 10, 13, 10, 0
  uploadfile            byte    $0[12], 0
  uploadfolder          byte    "uploads", 0
  tempNum               byte    "0000",0
  multipart             byte    "Content-Type: multipart/form-data; boundary=",0
  boundary              byte    $2D, $2D
  boundary1             byte    $0[64]
  'loadme                file    "TogglePin0.binary"
  • eagletalontimeagletalontim Posts: 1,399
    edited 2012-09-29 18:49
    not sure if this will help or not, but I would think that changing this :
                   outa[16]~~
                    outa[16]~
    To :
                   outa[16]~~
                    DIRA[16]~~
    will fix your problem
  • PodionPodion Posts: 90
    edited 2012-09-29 19:05
                   outa[16]~~
                    outa[16]~
    To :
                   outa[16]~~
                    DIRA[16]~~
    Ok I will give it a try ! Thank you. :-)
    edited 2012-09-29 19:06
    Podion wrote: »
    Short answer: Yes, it is possible.
    I don't know it it's possible with the code you're using.
    It looks like one of your Props uses Beau's Prop to Prop code while the other uses Mike G's Spinnerete code.
    I wouldn't think the two would communicate with each other.
    I don't see Beau's objects used in the second Prop's code anywhere (there's a lot going on in the server code so I may have missed it).
    Edit: I did miss seeing Beau's code. Sorry. That's a lot a code to wade through. It might help to write some simple Prop to Prop test code without all the internet stuff.
    edited 2012-09-29 20:30
    I also use :
    DIRA[16]~~
    OUTA[16] := 1 ' On
    ' or
    OUTA[16] := 0 ' Off
  • idbruceidbruce Posts: 6,197
    edited 2012-09-30 05:48
    Podion
    Yes, it is not only possible, but they do it in residential electrical construction all the time. I don't have the switching combinations down as in poles and throws, but here is how it is done with very common three-way and four way switches, with 120V single phase wiring. The same principle can be adapted by using switches with the appropriate poles and throws.
    Bruce
    EDIT: What is your current wiring schematic for the light and pushbuttons?
    EDIT: In fact, with this type of configuration, the number of switching locations is pratically endless. Just keep adding four-way switches in between the two three-way switches.
    718 x 432 - 29K
    edited 2012-09-30 07:33
    idbruce wrote: »
    Bruce,
    I suppose we can let Podion correct us, but my interpretation of the problem was to have push buttons connected to two different Props. Each Prop would have an "on" and a "off" button. My guess is, these "on" and "off" buttons should control a LED on only one of the Props.
    By using microcontrollers, the wiring can be kept very simple since the uC can take care of the logic.
    edited 2012-09-30 07:41
    @Duane
    Whatever the case, I believe the logic would be equal to the switch states of the circuitry shown. And I believe that if it was controlled logically, as in 1s and 0s, I believe it could be done with four single pole pushbuttons.
    edited 2012-09-30 07:48
    In fact, I think that might be a cool object for the OBEX. Using single pole pushbuttons as three-way and four-way switches to control a lighting circuit.
    Something such as the functions: AddThreeWayPB(PIN), AddFourWay(PIN)
    If the logic was correct, a person could control a light circuit from numerous locations.
    EDIT: More like this
    AddThreeWayPBs(3W_START_PIN, 3W_END_PIN, LIGHT_PIN), AddFourWayPB(PIN, LIGHT_PIN)
    EDIT: With the addition of more functions such as GetThreeWayState(PIN), SetThreeWayState(PIN), GetFourWayState(PIN), SetFourWayState(PIN)
    EDIT: However, if spare pins are available, the same circuitry could be replicated with the spare pins
    EDIT: Or simply tie the light to a pin, monitor the state as on or off, and if one of the pushbuttons is pressed, simply change the state of the light pin.
    edited 2012-09-30 18:43
    @Duane Degn your are rite.
    There is a code that I simplify. The principle is the same, 2 prop work in serial to control 1 light via 2 ON button and 2 OFF. Each prop have is own ON/OFF button. In reality those button are a IR remote. remote code 1 = On 2=Off / 3=On 4=Off.
    The 3 way don't work for this. the logic of the tree way : Off+Off=Off, On+Off=On, On+On=Off, Off+On=On and this is not what i want.
    *  HighSpeed Server         DEMO v1.0 *
    Revision History:
    CON
        RX_Pin       = 27
        TX_Pin       = 26
        _irrpin      = 24     'ir receiver module on this pin
       &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;//&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
       &#9474; &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;               &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;    &#9474;
       &#9474; &#9474;   Propeller 1   &#9474;               &#9474;   Propeller 2   &#9474;    &#9474;
       &#9507;&#9472;&#9508;RX             TX&#9500;&#9472;&#61629;&#61630;&#9472;&#9523;&#9472;&#9472;&#9472;//&#9472;&#9472;&#9472;&#9523;&#9472;&#9508;RX             TX&#9500;&#9472;&#61629;&#61630;&#9472;&#9515;
       &#61628; &#9474;     Client      &#9474;    &#61628;        &#61628; &#9474;     Server      &#9474;    &#61628;
       &#61464; &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;    &#61464;        &#61464; &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;    &#61464;
      Vss                      Vss      Vss                      Vss
       &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;/.../&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;/.../&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
       &#9474; &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;                  &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;                  &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;    &#9474;
       &#9474; &#9474;   Propeller 2   &#9474;                  &#9474;   Propeller N   &#9474;                  &#9474;   Propeller 1   &#9474;    &#9474;
       &#9507;&#9472;&#9508;RX             TX&#9500;&#9472;&#61629;&#61630;&#9472;&#9523;&#9472;&#9472;&#9472;/.../&#9472;&#9472;&#9472;&#9523;&#9472;&#9508;RX             TX&#9500;&#9472;&#61629;&#61630;&#9472;&#9523;&#9472;&#9472;&#9472;/.../&#9472;&#9472;&#9472;&#9523;&#9472;&#9508;RX             TX&#9500;&#9472;&#61629;&#61630;&#9472;&#9515;
       &#61628; &#9474;     Client      &#9474;    &#61628;           &#61628; &#9474;     Client      &#9474;    &#61628;           &#61628; &#9474;     Server      &#9474;    &#61628;
       &#61464; &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;    &#61464;           &#61464; &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;    &#61464;           &#61464; &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;    &#61464;
          of a collision.
    it can write to.
    VAR
    long   Buffer[10]
    long    Buffer1[10]
    long    keycode
    long    cogStack[500]
    long    stack[20]
    OBJ
    PUB Main
     Start_IR
    PUB Start_IR
        Start_IR1
    PUB Start_IR1
                           'start the tv terminal
      dira[23]~~
      repeat
        start
        start1
          next
        else
    PUB start
          case keycode
           1 :  bytemove(@Buffer,@NB1,strsize(@NB1))' <- Moves TestMessage into Buffer
           2 :  bytemove(@Buffer,@NB2,strsize(@NB2))
           3 :  bytemove(@Buffer,@NB3,strsize(@NB3))
           4 :  bytemove(@Buffer,@NB4,strsize(@NB4))
           5 :  bytemove(@Buffer,@NB5,strsize(@NB5))
           6 :  bytemove(@Buffer,@NB6,strsize(@NB6))
           7 :  bytemove(@Buffer,@NB7,strsize(@NB7))
           8 :  bytemove(@Buffer,@NB8,strsize(@NB8))
           9 :  bytemove(@Buffer,@NB9,strsize(@NB9))
           22 : bytemove(@Buffer,@NB22,strsize(@NB22))
           other : bytemove(@Buffer,@NB0,strsize(@NB0))
    pub start1
          comm
    PUB comm
        repeat 1
        return
    Dat
    NB0   BYTE 999,0
    NB1   BYTE 1,0
    NB2   BYTE 2,0
    NB3   BYTE 3,0
    NB4   BYTE 4,0
    NB5   BYTE 5,0
    NB6   BYTE 6,0
    NB7   BYTE 7,0
    NB8   BYTE 8,0
    NB9   BYTE 9,0
    NB22    BYTE 22,0
    CON
    Revision History:
    CON
        RX_Pin       = 27
        TX_Pin       = 26
        USB_Rx       = 31
        USB_Tx       = 30
        temps        = 1
      Vss                      Vss      Vss                      Vss
          of a collision.
    it can write to.
    VAR
    long    Buffer[10]
    long    Buffer1[10]
    long Stack[400]
    long Stack1[400]
    long    seed
    long    keycode
    OBJ
    PUB Main
     Start_IR1
    PUB start|debugLED
        repeat
          Menu_Principal
    PUB Start_IR1
      dira [16]~~
      repeat
          next
        else
       case keycode
        3: outa[16] := 1
        4: outa[16] := 0
      return
    PUB Menu_Principal
      dira [16]~~
      case Buffer
       1: outa[16] := 1
       2: outa[16] := 0
    Dat
    NB2   BYTE 1,0
    Client_DEMO.spinHSp2pRX.spinHSp2pTX.spinir_reader_sony.spinMain.spinServer_DEMO.spinSimple_Numbers.spin
    edited 2012-10-01 00:48
    I'll look at your code tomorrow (ahem later today) ... I suspect though you could have each propeller with a switch act like a one shot to a specific memory address that you are passing to all of the other propellers. This way if anybody gives an ON signal the memory address gets set, otherwise, if anybody sends an OFF signal the memory address gets cleared. Doing that would allow for 2-propellers, 3-propellers, ... N-propellers, whatever to control the same lighting
    edited 2012-10-01 07:07
    Podion,
    One thing I see in the Client portion of your code is that you are never calling the PUB start|debugLED routine.... where you have the High speed RX and TX routines. Also, you should be able to do this using only one buffer instead of two. That would eliminate some redundancy with transmitting and receiving.
    When attaching files, can you use the File-->Archive-->Project and then attach the resulting file? This makes sure that we have all of the pieces when trying to look at code.
    Thanks.
    I'll try to setup a demo using some of my original code to show how a 3-way or even a 4-Way switch might work as I explained in an earlier post.
    edited 2012-10-01 10:46
    The PUB start|debugLED is manage by the Main.spin
    Main.spin
    CON
    VAR
      long  cogStack[400]
      long  routine1_cog, routine2_cog, routine3_cog
    OBJ
      IR    :       "Client_DEMO"
    PUB Go
     waitcnt(cnt + (clkfreq * 2))
     cognew(Parallel_Routine_1, @cogStack[0])
     cognew(Parallel_Routine_2, @cogStack[200])
    PUB Parallel_Routine_1
       IR.start
    PUB Parallel_Routine_2
      IR.Main
    edited 2015-09-27 00:45
    Podion,
    I just went from your latest example... in that, the PUB start|debugLED routine was not referenced. None the less, here is a bit of revised DEMO code from my original code that shows how to implement a switch function across multiple Propellers to control lights, etc.
    On each Propeller the 'switch' acts like a one-shot, where it's only acted upon if there is a change in its state. If there is a change in state, that state gets passed along to the other Propellers in the loop. Both Clients and Server have control of a memory address (pre defined in your code) that determines if the lights are on or off. Note: the DEMO uses the 8 leds built into the Propeller Demo board and/or the Propeller QuickStart as well as the Def-Con badges.
    Because the switches are setup in one-shot mode, there is a possibility that you may want to turn the lights OFF but the switch at your location is already OFF. In this case you will need to turn the switch ON, and then OFF to take control of the lighting. The opposite is true if you want to turn the lights ON and the switch position at your location is already ON. You must first turn your switch OFF and then back ON. If however your switch matches the current state of the lighting situation, then all you need to do is move your switch to the desired position.
    edited 2012-10-03 15:20
    I replace the PUB start|debugLED by PUB comm on the server side.
    I tried to adapt your code in mine and I'm not successful. I do not know if it's because I use an IR code and I have no real switch, in my code the IR keycode is the switch. The light i want to control is only plug to the client propeller.
    Revision History:
    CON
        RX_Pin       = 27
        TX_Pin       = 26
        Command      = %0000  '' Feature not used in this demo
        USB_Rx       = 31
        USB_Tx       = 30
        temps        = 1
      Vss                      Vss      Vss                      Vss
          of a collision.
    it can write to.
    VAR
    long    Buffer[10]
    long    Buffer1[10]
    long Stack[400]
    long Stack1[400]
    long    seed
    long    keycode
    OBJ
    PUB Main
     Start_IR1
    PUB start|debugLED
        repeat
          Menu_Principal
    PUB Start_IR1
      dira [16]~~
      repeat
          next
        else
    [COLOR=#ff0000]    case keycode[/COLOR]
    [COLOR=#ff0000]      3: outa[16] := 1          'LED ON  Control by client  [/COLOR]
    [COLOR=#ff0000]      4: outa[16] := 0          'LED OFF Control by client    [/COLOR]
      return
    PUB Menu_Principal
      dira [16]~~
      case Buffer
    [COLOR=#ff0000]    1: outa[16] := 1           'LED ON  Control by server[/COLOR]
    [COLOR=#ff0000]    2: outa[16] := 0           'LED OFF  Control by server
    [/COLOR]
