figuring out humidity and tempertaure
Sandhuamarinder
I am trying to figure out humidity and temperature in my basement now using basic stamp. Now the question is if i got these to sensors how i will calibrate it is there a way to calibrate it using stamp. Or i can get it from some one and throw some data into the stamp.
Which sensors?
So just wondering Sir do i need to calibrate it if yes then how.
Just trying to figure out basement temperature since it gets pretty humid after bath shower.
Here is one
http://www.hwsensor.com/English/Humidity-Sensor/gas201112890902.shtml
but i havent looked into any no specialization i just need more accuracy then which are sitting on ebay and on amazon .Does not look good looking into people reviews any idea
And place where i can buy more accurate humidity sensor. I will probably need further help also later in programing.
Its been while for me to get back to things.
Out from school from while almost 2 years now.
I have used the Sensirion sensor. It does not need calibration and works very well. It does require some complex mathematics which I'm not sure if the Basic Stamp could handle. I've only used it with a Propeller microcontroller myself.
Where you hoping to use a sensor with a Basic Stamp or did you have some other microcontroller in mind?
Thanks for the help.
So now question is where i can buy this sensor. Looking at the parallax website its pretty expensive. I am looking for cheaper price some where.
Any place on the website.
can i buy it from sensirion website.
The lm34 is probably a better fit for what you want to do, since the ds1620 has additional features perfectly suited to using it as a thermostat.
Then, for humidity, get the hs1101 for 9 bucks, and poof, less than 20 bucks, some programming, and you have exactly what you're after, humidity and temperature, and no calibration necessary.
Parallax has documentation on both of these devices, and I've found their docs to be excellent (for the most part) so you should have no trouble building your sensor pack.
You can find more about interfacing it to the BS2 for temperature and humidity on my web site here.
Sandhuamarinder, The SHT15 in Tracy's link is an excellent deal and appears to be the best option at hand.
If you are able to wait a while, I will have another batch of my modules in a few weeks as I will have some excess from a commercial order (I round up to save costs and then sell the extras). The SHT11 modules are $18 and the SHT15 modules are $28 (that includes shipping). I will have some of each.
Since i dont wants to connect my furnace and air conditioner with it.
